Trying to formulate a plan for what all I'm going to do to overhaul the rear end of the notch next spring (the season, not the part, heh). The list thus far is basically better/wider tires (if I can find a set of cheap pony rims), Maximum Motorsports lower control arms, poly spring isolators (currently have none), and a set of springs ... which brings me to my question.
I'd like to find something to replace my current Eibach Drag spring setup. For one, they ride like crap. Secondly, the airbag is completely worthless - cracked n' dry-rotted, and the air line going to it keeps getting pinched off on stuff or melted by the exhaust. And third, they make the car sit kinda weird with the front end higher than the rear, even with the battery relocated back to the front, again.
I absolutely DO NOT want anything that'll make the car sit any lower, because I've got enough ground clearance problems right now, as it is, with my stupid UPR X-pipe. Should I look for a plain ol' set of OEM replacement Moog springs, or should I go for some progressive-rate FRPP "B" springs? Or maybe even 4-cylinder springs, if they'll help with weight transfer (and not ride like poo)?
Tried searching, but lowering things to the max seems to be all the rage, and that's what I'm trying to avoid.
Many thanks in advance!
4x4 look, lol
