rear suspension removal
  • Thread starter Thread starter undercnstrction
  • Start date Start date Jan 21, 2010
U
undercnstrction
312
  • Jan 21, 2010
now that i have the front suspension removed, i'm going to tackle the rear suspension. are there any words of caution/advice on taking it apart? do i need to take special precautions because of the shocks/springs being under pressure. i used a floor jack to hold up the a-arm on the front so the spring didn't rip my head off. are there similar precautions that need to be taken for the rear?
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Jan 21, 2010
  • Jan 21, 2010
I would get the car in the air first, then remove the E-brake cables, brake lines, quad shocks, and main shocks. This gets the rear end to drop down quite a bit. Next remove the springs with a spring compressor. If you don't have one, that's okay. You can get a jack under the rear mounting bolt of the rear lower control arm. Take the bolt out, then lower the jack down slowly, the rear spring will release it's tension and fall out. Then take out the UCA and LCA bolts and everything is out.
U
undercnstrction
312
  • Jan 21, 2010
sounds easy enough. thanx!
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jan 21, 2010
  • Jan 21, 2010
+1, The rear springs are soooo much easier than fronts.
I've said it before, using a ratcheting strap to hold the axle in place when taking off or putting on control arms helps a ton. That rear end is heavy and under a lot of pressure, so when you start taking things off of it that hold it in place (shocks, control arms, etc), its going to try to get out of whack on you and make it hard to remove or install bolts.
SVT32VDOHC
3,501
28
119
Motor City
Jan 21, 2010
  • Jan 21, 2010
^^Yup...it's a PITA sometimes to get in aftermarket UCA and LCA's. On the two notches, it was a PITA. But on this hatch it was much easier since I used stock uppers. The lowers went right into place. I bolted the uppers to the car, then moved the rear end up and slipped the bolts in the housing for the UCA's. Much easier than aftermarket UCA's.
SpartaPerformance
2,517
61
89
Long Island NY
Jan 21, 2010
  • Jan 21, 2010
I would always put the car on jack stands then put a floor jack under the pumpkin of the rear, once all the lines and shocks are unbolted then you can slowly release the floor jack and the whole rear will drop out if that's your plan but if you're just installing suspension parts you should do it one side at a time, at that point the rear springs can be removed quite easily by hand.
fiveohwblow
Official Member
2,169
145
155
Jan 21, 2010
  • Jan 21, 2010
Another issue that can be had is if you have a car that has been driven moderately hard when you remove the control arms if the car has "flexed" at all the holes dont always line up perfectly. Using something to help wedge in conjunction with the jack always makes it a bit easier, but not much.
U
undercnstrction
312
  • Jan 21, 2010
as far as i know everything will need to come out. i'm converting to 5-lug and 4-wheel disc. i'm also going to be adding a panhard bar and torque arm. i'm still not sure about the rest of the suspension though. i'm guessing it will be some form of lowering springs/shocks instead of coilovers. MM advised against coilovers, although i can't remember why.
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
