89MustangGX said:Something's wrong here.
Are you positive it's the inner fender, not the exhaust or quad shock? You should definitely rub those before you get to the inner fender IMO.
iapexl8r said:Might I suggest the use of a big f@$^ing hammer. just gently massage the area with the witness marks (where you can see the tire was rubbing) with the hammer. some times you can get masking tape to stick to it (where you just beat on it) put the tape on it and drive (white spray paint will work also). do whatever causes the rubbing and repeat the process, on the new witness mark if it still rubs. hope this made sense chris
