Rear Tranny seal install
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
Heya, i finished putting my tranny (1991 t-5) back togetehr last night, and noticed after i had it all back toegther, that i forgot to change out that rear seal where the driveshaft slips in it. please tell me its easy to do with the tranny together :) and i read something about people having problems with parts store seals back there.. should i just go for the FoMoCo version to ensure it doesnt leak?
Thanks in advance for any help :SNSign:
I am pretty sure you can just pry it out carefully with the tranny installed, and the drive shaft out. I would definately use a genuine FoMoCo part. Then tap the new seal in using a socket of the exact same diameter of the seal or a piece of wood cut to that diameter so it goes in evenly and doesn't warp. They may even make a tool specifically for this. Do it slowly, watching to make sure it is going in evenly. I have never actually done this, so I would refer to a manual to see if you need to use some sort of lubrication, or maybe someone smarter than me will chime in on this. :D
Apply with your finger a little ultrablack on the inside where the new seal is going to mate up to the tailshaft housing and you should be good. That will lube it and when it sets it's sealed for sure. I just used a hammer and lightly tapped around the seal. Dont forget to grease the seal when you install the tailshaft.
Kevin
