Rearend fitment?
What's the narrowest rear that'll fit in a 66 fastback without any trouble?
I've found an 8.8 that's been narrowed to 55.25" from mounting surface to mounting surface, and was wondering if that would work for me, or if i would run in to trouble? Anyone know? I'd really like to jump on this deal if it'll work.
Well I would imagine that depends alot on what size tire and wheel your using. Also where the spring perches are. I am not sure how wide a stock 66 rear is but a friend of mine just got 59 9" which is 57.25 and that supposed to fit right in the 65-66's. You might run into trouble with the inner wheel wells. Though you might be able to compensate for that with backspacing.
There aren't any spring eprches on it, I'd have them welded on to fit. Like you said, I'm wondering If I'd have trouble with the inner wheel wells, or if that could be compensated for with backspacing. I would think I'd have trouble with my stock wheels, and if that were the case I'd throw on some cheap wheels to be able to get by.
Thanks for the reply 68
Basically i want to know the limit of what can be run without cutting the inner wheel wells, and if any fitment problems could be compensated with different wheels.
Thanks guys.
Just run a wheel with less backspace
You're basically 1" shorter per side with the axle you want to buy than a stock rear end. As an example Instead of a 4.75" back space on a 17"x8" rim you could run a 3.75" backspace and have a nice deep looking rim. Reminiscent of the 5 spoke racing wheels on the original GT350. (IMO) this would look really sweet!
See if you can't photoshop some deep dish rims onto the back of your car to see what you think.
Good luck,
Scott
Good luck,
Scott
Thanks a lot man! That's exactly what I wante to hear! Glad to know it's do-able without wheels spacers or whatever.
Also, what is the backspace on stock wheels like these?
* Not my car, found it on google images.
Actually 56.25" when measured from the wheel mounting points
Which means I was incorrect. it's 1/2" per side.
Sorry about that. I'm still working on learning fractions :bang:
Thanks mdjay, I hate when I give out bogus info.
I do not know the back space for rally rims, or if there is a difference between the early rally rims or later model Rally rims.
Scott
What are your measuring points?
LUCAFU1 said:
the 65-66 rear housing is 52.25" long. add another 5' for axles it comes to 57.25". so basically that 8.8 is a inch shorter on each side. youll be okay.
I've measured three rear ends all for the '65-'66 (8", 9" and 7.5"). All three were 56.25" from the wheel mounting flat of the drums. Not sure where your getting 57.25".
i measured 2, my 66 *" and a 58/59 ford axle. I thne measure the axles so i could order some mosers and those were 30 3/8" and 26 1/8" which equals 56 1/2". then there is that gap inside the locker (axles dont touch), thats how i got 57 1/4" (estimate). but theres no way mine was less the 56 1/2". it sounds like maybe you took your measurements from the back of the axle flange? i would go and verify this tomarrow but ive seen then narrowed that rear 2" on each side.
Nope
bolted the drums down and measured from the face of where the wheels mount.
******Edit*************
Well open mouth insert both feet. I just went back and checked my notes and, I'm a total moron. The measurements I got were 57.25". Sorry for any confusion this caused.
******End of edit********
