Rearend offset
  • Thread starter Thread starter Opposedodie
  • Start date Start date Aug 13, 2011
Opposedodie
121
  • Aug 13, 2011
Just got done putting my tires and wheels back on and noticed the my tires are setting off to one side (the Passenger side) about 1 inch farther out than the drivers side , Is this factory or do I have a problem? The rear end is all new from lug nut to lug nut . I have driven the car down the road and had a friend follow me and it is not dog tracken at all .. just one of them little things that drive me crazy.... Here is 2 pic's ...
DSCF5873.jpg picture by opposedodie - Photobucket
DSCF5874.jpg picture by opposedodie - Photobucket
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Aug 13, 2011
  • Aug 13, 2011
I've yet to meet a 79-up Mustang with a solid axle that wasn't off set to one side by some amount. It's just a characteristic of the type of suspension. It can be cured with a panhard bar/torque arm/high dollar suspension, but there's not much more than can be done without throwing a bunch of money at it.
Rick 91GT
Mustang Master
95
99
PA
Aug 13, 2011
  • Aug 13, 2011
Did you replace the upper control arm bushings? Did you put the sleeves back in the correct location?
Opposedodie
121
  • Aug 13, 2011
I have a new (600 miles new) UMI performance suspension front and back in this car , with the rear adjustable upper links..
Opposedodie
121
  • Aug 13, 2011
Just got out from under the car and took a good look with a tape messure and found that i am out to the passenger side of the car 5/8 of an inch more than the drivers side , looking around I can not find anything wrong .... spacer time if i can not come up with anything
PUNISHER RACING
1,124
FORD CITY, PA.
Aug 13, 2011
  • Aug 13, 2011
are ur uppers the same length? as well as the lowers
Opposedodie
121
  • Aug 13, 2011
here is a pic of the difference ... will measure to see if the uppers are the same, lowers are at a set distance and cannot change..
DSCF5879.jpg picture by opposedodie - Photobucket
DSCF5878.jpg picture by opposedodie - Photobucket
Opposedodie
121
  • Aug 13, 2011
Well so much for paying someone to install the rear suspension . .. I have 9 and 1/8 inch from center of bolt to center of bolt and on the drivers side i have 9 and 5/8's... so what to adjust ?
PUNISHER RACING
1,124
FORD CITY, PA.
Aug 13, 2011
  • Aug 13, 2011
most are adjustable on car, if not drop the front (top) bolt out and set it to 9" both sides to start if its a stick car
Opposedodie
121
#10
  • Aug 13, 2011
  • #10
They are adjustable , I looked at them both and the one on the passenger side looked like it was stretching the bushing so I pulled it and gave it the 1/2 inch it was lacking from matching the other side put it back in and I still have the same problem, Axle is not cantered in the car... off by a 1/2 inch .. the top control arms are set at 9 1/2 inches and it is a stick car .... should i set at 9 inches ? I drove the car and nothing is making any noise ... suspension is set up for the strip, hit a bump in the road and you feel it...
PUNISHER RACING
1,124
FORD CITY, PA.
Aug 13, 2011
#11
  • Aug 13, 2011
  • #11
get sum measurments from under the car to the torque box centerlines, make sure the car is square. ur torque boxes could be pulled and that could also be ur issue. If thats the case u might need to set ur rear arms up to compensate for it
1991vert
1,103
Ludlow, MA
Aug 13, 2011
#12
  • Aug 13, 2011
  • #12
i had a radius rod style upper control arm with heim joints and the part that went into the upper torque boxes had spacers. well the arms didnt come with instructions so i just installed them. my rear end was off to one side. i thought hmmm...and got back under the car. i had installed the spacers backwards flipped them around and was good to go.
Rick 91GT
Mustang Master
95
99
PA
Aug 14, 2011
#13
  • Aug 14, 2011
  • #13
FWIW, there is 3/4" offset built in to the driveline in the car, be careful where you are pulling your measurements from. The motor all the way back is offset 3/4".....
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,147
2,779
224
Vass, NC
Aug 14, 2011
#14
  • Aug 14, 2011
  • #14
I see, said the blind man...
This is a fact I recognize, but had forgotten. I feel like that saying, "I've forgotten more about mustangs than..."
Opposedodie
121
#15
  • Aug 14, 2011
  • #15
I have heim joints on the upper arms and the spacers are the same size .. I will do some measuring today to see if i can find out what is going on ... My torque boxes have some damage but are not broken and have not been upgraded as far as i can tell, looks stock.. Looks like some one used it as a jack point ..... more than once .. i will take a few pics today ...
J
Rear alignment issues
  • Jayjay001
  • May 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
