I recently put in amsoil synthic fluid in the rearend, along with a TA perfermance girtle and cover. Since then when at the track i'm only getting one tire at first then both but not that good on the driver side. When i launch with slicks it wants to pull to the driverside do to poor traction. I have all the syspension mods done including an air bag on the passenger side, the car use to launch stright and level. So i thought it was due to the ratio of fluid verses modifier. So i added another tube and still the same? So do you think it's because of the synthic fluid, getting on the clutches? If so how would i drain all it out and get the clutches cleaned off of the fluid to install regular fluid? Or do you think now i just need to add more clutches? I have the 8.8 with new trac lock and 4.10 gears. peace
john
john
