Removal of 01, v6 headlight switch
Are just needing to remove the knob so you can take the bezel off? If you pull the light switch to turn the lights on you will find a small notch in the plastic knob close to the bezel. Now get a pick that has a 90 degree tip and put in the notch and pull on the pick and then on the knob and it should pull off. What you are doing is pulling on the metal spring like clip that holds the knob on to the rod. Then push the rod back in to turn the lights off and pull the bezel off, thats it. Hope this helps.
