removing e-brake cable
  • Thread starter Thread starter load71
  • Start date Start date Aug 4, 2005
load71
68
  • Aug 4, 2005
Hey do u remove the cable from underneath the car. I am taking the whole rear out of the car and putting it into another, so i figure it would be easier if I just remove the cable from the handle, instead the of the rear. Any help would be great. Thanks
txstang84
1,639
42
69
Tuscola, tx
Aug 4, 2005
  • Aug 4, 2005
are you staying drum brakes? if you are, just pull the swedged end out of the shoe, and compress the little tangs together and pull them from the backing plate
if your converting to discs, you'll need to remove the whole thing which entails the first part, and doing the same thing with the part of the cable that attaches to a fixture directly up and inboard of your mufflers, then they run up to a "splitter" directly under your ebrake handle...
also if your swapping to rear disc, you'll have to modify your ebrake handle, or swap one in from a 79-86 (manually adjustable) or possibly one out of an SN95
to tag along with the disc conversion, you'd also have to get different cables (M-2809A (2ea) and M-2810 fwd section)...I personally used SVO type (same thing as the part numbers above) cables from the local Advance Auto...same thing, and about $20 cheaper per pair.
load71
68
  • Aug 4, 2005
No im staying drum brakes. I want to keep the cables connected to the rear, i just want to disconnect it from the handle. Is this possible? Or do i have to disconnect it from the rear.
txstang84
1,639
42
69
Tuscola, tx
Aug 4, 2005
  • Aug 4, 2005
oh yeah, very possible, just release your ebrake, pry them loose from the splitter up behind the driveshaft, then follow the cables down to the quadrants, push all the little tangs down, and pull it through the hole-it can be a PITA, but just have some patience, and they'll come off fairly easily
281pony
2,681
Oly, WA
Aug 4, 2005
  • Aug 4, 2005
i ended up using hose clamps on the e-brake cables thanks to a suggestion on here.
with the hose clamp in place, i tapped it a few times with a rubber mallet, it got them through after trying everything else.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 4, 2005
  • Aug 4, 2005
That was probably me that offered that suggestion as I tried everything under the sun before putting the hose clamp on and they came right out after that!
txstang84
1,639
42
69
Tuscola, tx
Aug 4, 2005
  • Aug 4, 2005
...guess i was lucky getting mine out-most definitely a great idea though!
281pony
2,681
Oly, WA
Aug 4, 2005
  • Aug 4, 2005
yeah i think it was you. i still went through hell before that.
i took the cables off at the e-brake handle above the driveshaft. then i used a dremel to cut them off right before the fitting, and still ended up needing to remove them.
i had tried pliers, vice-grips, everything and they wouldnt come out. so i put the hose clamp on one more time and smashed that damn thing and it flew out.
in my case though they were not going back on, so you might want to be a little more careful
load71
68
  • Aug 4, 2005
Thanks guys i going to give it a shot tomarrow night.
SCcopcar
326
Oklahoma
Aug 5, 2005
#10
  • Aug 5, 2005
  • #10
I slid a box end wrench over them to release them to come out of the hole
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Aug 5, 2005
#11
  • Aug 5, 2005
  • #11
I tried that, along with a socket, tie wraps, everything you can think of, I was about to cut the damn tangs off and then seen those little hose clamps up on my bench and said what the hell I tried everything else!
fox racer
577
Staten Island, NYC
Aug 5, 2005
#12
  • Aug 5, 2005
  • #12
wat i didt was yank on the cables, as if i were removing them. then with a long screw driver (flat, skinny) i flattened each tang that holds it in, very easy and quick.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
