Gents,
I took her out for a spin yesterday. I am hearing what I suspect may be my speedo cable making a bit of a racket inside the cabin or at least that’s where it seems to be coming from. The speedo does work fine though. No jumping, cruise control works, etc. it’s a Hard sound to describe. Maybe “static sound” like from speakers is the best I can say to describe what sounds like coming from behind the dash. Like something “tingling” around back there if that makes sense. It really kicks when I accelerate and continues to do so but not as bad when coasting but then nothing when stopped.
My plan is to disconnect the speedo but leave the VSS in place so I can drive and see if the noise disappears. I found an old post where our awesome friend @jrichker posted not to remove the hairpin clip that holds the cable inside the VSS because chances are we won’t be able to get it back in place to hold the cable again upon re-installation.
I trust 1,000% what he says so i am cautious about pulling the pin to get the cable out. However if there is a chance I can get it back in place then I’m down to try it. I’m a glutton for punishment.
With that said, any of you guys have any suggestions on pulling the cable from the transmission side without removing the VSS?
I’d rather not take my dash/guage cluster apart if I don’t have to. Any tips for disconnecting the cable would be helpful.
It’s a 91’ AOD by the way.
