Roush Replacement gauges?
SVT Saleen
456
Whilst detailing the Speedster's interior yesterday afternoon, the trim ring/lense cover on the boost/vacuum gauge cracked almost all the way around where it attaches to the body of the gauge.
I'll attempt to super glue the ring/cover back in place as a temporary repair, but I would probably prefer to acquire a replacement gauge just in case the glue doesn't hold completely.
Unfortunately Saleen Performance no longer lists individual gauges or the dash top gauge pods on their website so I wanted some advice on who might have a set of Saleen-logo boost/vacuum & fuel pressure gauges.
Any leads would be appreciated.
After much soul searching I've decided to replace both OEM Saleen-logo gauges with AutoMeter gauges. Even though the Saleen gauges appear to be sourced from VDO & just replacing the broken vacuum/boost gauge with a comparable VDO is the cheapest solution, the two gauges won't match one another. If there is one thing for which I'm a stickler, it's esthetics. The idea of having two distinct items in one readily visible location would drive me nuts.
So, I'm going to purchase matching Phantom vacuum/boost & fuel pressure gauges.
Now my follow-up question. I assume the vacuum/boost gauge is a mechanical gauge as I've never seen an electronic gauge. Paradoxically I assume the fuel pressure gauge is electric because it is mounted within the interior so some type of isolator has to be installed.
Are my assumptions correct? I want to be certain prior to purchasing the AutoMeters.
Thanks again for any assistance from my fellow Saleen/Stangnet compadres.
