HEy guyz, I was just wondering if you can get a new ignition cylinder lock that is keyed with your door locks so you can still use one key for everything? My friend snapped a key in my current cylinder (car starts fine but I cant remove key remnants from the cylinder) and the ears are sloppy anyways causing constant chiming when the door is open etc, so I wanted to replace it anyways.Again, I'd like to have one key operate all locks if possible, like stock.
ALSO, On rockauto.com there are 4 different ford part numbers and 4 key codes listed with the lock cylinders. Why is this...possibly because a certain key code matches certain door lock cylinders? Can anyone shed some light on this? Heres the 4 part numbers and descriptions from rock auto:
MOTORCRAFT Part # SW2397 {#F3DZ11582B}
No. 2 Cut Letter B
$36.99 $0.00 $36.99
MOTORCRAFT Part # SW2398 {#F3DZ11582C}
No. 3 Cut Letter C
$36.99 $0.00 $36.99
MOTORCRAFT Part # SW2399 {#F3DZ11582D}
No. 4 Cut Letter D
$36.99 $0.00 $36.99
MOTORCRAFT Part # SW2400 {#F3DZ11582E}
No. 5 Cut Letter E
$36.99 $0.00 $36.99
(sorry the cut and paste job shifted the prices...there all $36.99 if that helps)
No. 2 Cut Letter B
$36.99 $0.00 $36.99
No. 3 Cut Letter C
$36.99 $0.00 $36.99
No. 4 Cut Letter D
$36.99 $0.00 $36.99
No. 5 Cut Letter E
$36.99 $0.00 $36.99
