Replacing Oil Pan
BUF92GT
12
Buffalo, NY
Noticed an oil leak under my 92 Hatch the other day which has been stored since end of October. It looks like the oil pan is leaking probably from the gasket. The plan is to replace and upgrade to a 7qt. pan.
My questions are:
1) Can anyone recommend a good 7 qt pan that will fit the stock 302 engine without any mods?
2) How difficult is it to get the pan off/back on - I am not pulling the engine.
Any advise would be great as I have never really done ANY engine type work before. I have only had the car since Aug.
Thanks to everyone in advance.
the pan is pretty difficult to change in the car. You're going to have to unbolt the engine mounts and raise the engine as far as it will go (bellhousing touching your firewall/tunnel) and unbolt anything that would otherwise get bent or damaged in the process. Then HOPE you can get it out from there.
I am curious... why get a 7 quart pan? Have you tried snugging up your current pan to see if it stops leaking? have you considered just replacing the pan gasket, which would be a MUCH easier job?
Been there, done that - You can do it in the car, but it is hard to do. The best way is to pull the engine.
Disconnect the battery at the battery ground terminal, remove the fan and fan shroud. Both motor mounts will need to have the large nuts that secure them to the frame removed. The trans mount will also have to be loosened, and it is a good idea to remove the drive shaft.
I also had to disconnect the cat pipes at the headers to get the engine high enough to remove the oil pan. Be prepared to have to drop the steering rack and disconnect the steering shaft. Jack up the engine with a wood block under the oil pan and watch for things that bind or hoses/electrical wiring that may need to be disconnected. I put a couple of wood blocks between the headers and the frame to support the engine. You will likely need to jack up the rear of the transmission as well to get the required clearance.
Scrape the pan mating surfaces clean as possible - old gasket stuck to the surfaces are a source of leaks.
Get a high volume/heavy duty pump, and a replacement HD pump shaft. FMS makes one, and ARP does too. When you install the pump, the funny looking washer thingy goes on the part of the shaft that fits into the hex socket in the distributor shaft. It keeps the shaft in place when you remove the distributor, which you will have to do to prime the pump. Forget to put it on, and the pump shaft can come loose and fall down in the bottom of the oil pan.
There is a one piece oil pan gasket which will help re-assembly if you can find it. If you can't get this gasket, use weather strip adhesive to secure the cork gasket to the pan rails and the rubber strips to the bearing caps. Use lots of Acetone or MEK to clean the gasket surfaces so the weather strip adhesive will stick good. Read the instructions on the adhesive carefully to make sure the gaskets are permanently stuck in place and won't move when you slide the pan in place. Use lots of blue silicone sealer on top of the front and rear rubber seals where they mate with the pan.
Fill with oil, replace the filter. Reconnect the battery, switch the ignition on to enable the gages, but DON'T crank the car. Remove the distributor and use a 1/4" hex socket to turn the pump counter clock wise (same direction as distributor rotation) until you see oil pressure (an external gage is a great help long about now). And keep turning for about 30 sec after you see the pressure come up. A reversible drill is the best tool to use to turn the 1/4" socket. The pressure should come up to about 50-80psi with cold oil. Once you see good pressure, check for obvious leaks, and then and only then, lower everything back into place and bolt down the mounts and anything else you had to take loose.
Re-install the distributor and set the timing with the engine running using timing light (don't forget to disconnect the SPOUT plug and reconnect it when finished) 12-14 degrees BDC is good. Start up and check for leaks, let it warm up and look again for leaks. It took me 2 days plus, but I am old and slow, maybe your granny is faster.
I think you really need to decide if you truely want a new pan.
You can change the gasket without taking the engine out, but i'm not so sure you can get the pan completely off, even if you can, i'm thinking you are not getting a 7 quart with pick up, back on.
If you do change the pan, get a canton with windage tray tube and pick up. It aint' cheap, i think mine cost me somewhere around $400 for it all.
If you plan to do a k member change, nows the time.
IMO, fix the pan gasket, and leave it alone. My engine was out when mine was done.
Thanks for the advice. Once I get the car moved to where I can work on it I will check out everything you guys mentioned. That is certainly more than I wanted to tackle right now but if I can do it without too much trouble than I am gonna go for it. My concern is that I see rust on the pan - not sure how long its been there or if its surface rust or more - if its just surface I will probably just replace the gasket and plug and be done for now. I really don't want to get into taking the engine out - plus when I do that I have other things I want to do at the same time. Not enough $$$ right now for all of it though.
Again Thanks
I guess I would just pull the pan and fix it. I cannot see trying to jack or lift the engine enough to get to the pan gasket.
OH, I am doing this job this weekend because I let the car (the Capri) slip off the jack 2 weeks ago and the jack pad punched a hole in the front sump.
JB welded it, to slow down the leak, but I have to pull the motor, hammer the pan back out, weld it, and reinstall.
I love hot rodding!!!!!!
Have no idea how you'd do it in the car (replace the pan totally that is) both times I've had to change an oil pump in the car I had it jacked up until the bellhousing hit the firewall and there is no way I could have gotten the pan totally out, so I'm with the other guys :) just jack it up and change the gasket for now (be sure to get a 1 piece) and then swap oil pans when your ready to tackle pullin the motor.
If it is not pouring out oil just leave it alone. Just keep an eye on the oil level for the mean time and save your money until your ready to reseal the whole thing. A pan gasket can leak for years as long as it is minor and the gasket is not blow out or leakng bad. DO WHAT the others have advised, tighten the bolt you will be suprised with the results.
