Friend of mine just assymbled a 347, and had to resort to using a stock balancer. I had no idea it was stock untill i asked. The problem is the car vibrates like a damn jack hammer.
Two questions on this one:
1) he's using home made solid motor mounts....now, when i say solid, i mean 2 inches of solid steel plate. I know solid mounts cause some extra vibration, but how much more?
2) i personally think he needs a Fluidyne or equivelant balancer, so wouldnt the stocker cause more vibration, and wouldnt the two make it really bad?
Basically the car idles fine, just a little cam shake (X303) but shakes progressively worse as the RPMs go up, to the point of literally jack hammer-like at 3500+.
honestly, how would you forget somethign as critical as making sure you have the correctly weighted balancer/flywheel. Owell live and learn i guess. i sure hope he didnt ruin his bottom end. You can get nodular iron FRRP balancers and flywheels fairly cheap on the internet. like DSS has them for a 100 bucks each part. if you are a good friend you need to
your friend for stupidity.
