Reverse Grind
  • Thread starter Thread starter asecretfile
  • Start date Start date May 4, 2007
asecretfile
228
  • May 4, 2007
91 LX when shifting into reverse, clutch pedal to the floor...at a dead stop it grinds...if I shift out and back into reverse no grind at all. None of the other gears do it except reverse.
Time for a rebuild?
Thanks :SNSign:
asecretfile
228
  • May 4, 2007
Forgot to ask could my clutch need adjustment and just not be disengaging all the way?
Thanks
HISSIN50
34
129
May 4, 2007
  • May 4, 2007
It's normal. Most folks will hit a forward (synchronized) gear to slow the cluster down before going into R.
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
May 4, 2007
  • May 4, 2007
Mine does that too, sometimes. Mostly when the oil level goes down a bit (leaking oil seal)...
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
May 4, 2007
  • May 4, 2007
Actually if any of you still have your owners manual i believe in it it tells you to do that before you shift into reverse. Stop shift to first then shift to reverse. Since reverse doesn't have a syncro it is more prone to grinding.
G
genericstang
120
Marietta. GA
May 4, 2007
  • May 4, 2007
this use to happen all the time to me. i just shift into 5th then reverse, problem solved.
4G-KDMP
935
CA
May 4, 2007
  • May 4, 2007
x2
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
May 5, 2007
  • May 5, 2007
Every Mustang I have had which has been 11, 8 being sticks.....every single one grinded in reverse sometimes!!!!
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 5, 2007
  • May 5, 2007
I always go into 4th before i hit reverse....never grinds after that.
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
May 5, 2007
#10
  • May 5, 2007
  • #10
I built a new 89- early 93 spec trans, and I hated the grinding so much, I went back to the later 93+ spec trans because it has a synchronized reverse.
BAHRAINI_STANG
69
#11
  • May 5, 2007
  • #11
that what i do
A
ARTTII
272
Detroit, MI
May 5, 2007
#12
  • May 5, 2007
  • #12
All depends on where you have your clutch (cable) adjusted also... I found a happy medium by taking a bit more slack out of the cable, with the clutch grabbing somewhat higher on the pedal (but I never race, if you do this option definitly isn't for you!)
mustangkid05
199
#13
  • May 5, 2007
  • #13
idk
HISSIN50
34
129
May 5, 2007
#14
  • May 5, 2007
  • #14
I'll disagree here. It comes down to the cut of the reverse gear IMHO (if one doesnt have a blocker on reverse like Pacecar noted).
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
May 6, 2007
#15
  • May 6, 2007
  • #15
I always wondered why mine would grind if I didn't hit a foward gear first.....
cobra2798
303
Clermont, Florida
May 6, 2007
#16
  • May 6, 2007
  • #16
Both fox's ive owned have done this, I picked 3rd to use before reverse, otherwise my car shifts fine.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
