Right front brake dragging
Black GT
148
9
28
Jacksonville, Florida
I have a 2001 manual GT. It has gotten lately to where it seems almost like the parking brake is on. Today I took it for a ride. I stopped and bought gas and it started doing it afterwards. It felt like a rear brake dragging but when I got back home I felt all the wheels and the right front was so hot I could not hardly touch it. I am thinking it needs a caliper. Wondering if anyone has experienced a dragging brake and if replacing the caliper solved the problem?
So im hoping yours isnt the same but i have a horror story for dragging brakes....
So mine was doing the same except it was the rear for me I thought no big deal ill do both rear calipers and call it a day. changed with no difference so its an older car so i replaced the rear flex hoses as well because they are cheap but then i found a killer deal on front calipers so i decided why not. changed all pads, calipers, rotors, and flex lines. drove fine for a day only to come back hard. based on the suggestion of a friend I unplugged the harness plug to the abs pump, bled the hell out of the system and tested it and it fixed it. So i still dont have abs and left it unplugged because from what i can tell the abs pump is malfunctioning and pressure is going into brake lines but it wont return so its over pressurizing lines
I just went through a similar situation except it was driver's front. Decided to replace all rotors, front calipers and pads all around. Full fluid flush. I was like "oh, this car rolls now". LOL You described it perfectly. Felt like the e brake was on but the pedal felt weird, like the brakes were still on even though my foot was off it. American Muscle had a deal on stoptech cross drilled rotors and power stop red powder coated front calipers. Also replaced front rubber brake hoses. Original equipment. How many miles on the 01? I'm creeping up on 157k
