Rims...
since you seem confused, im gonna follow up on my post....;)
the first number is 245, which is the width of the tire in millimeters (not the rim). the second number is the percentage of that width that is the height (or sidewall). the last number is the width of the inside of the tire (which is the size rim diameter it can fit on). a lower profile tire will have a lower percentage per tire width. im guessing off the bat that you can probably run something like 255/45 17 on that cobra tire, maybe 265/55 17 im guessing. hopefully someone with those dimension rims will chime in.
