Rocker arms?
  • Thread starter Thread starter 91ghp5.0
  • Start date Start date Nov 27, 2006
91ghp5.0
42
Somewhere
Nov 27, 2006
  • Nov 27, 2006
I'm looking into my springs/rocker arms for my stock E7's. I'm currently running stock springs/rocker arms with a B cam. I've been told that Crane makes the alphabet cams for Ford, so I'll call them for a spring match. What 1.7 rockers though? Harland Sharp? Crane? Comp cams? Scorpion? FMS?
I'm experiencing a little valve float and lack of "oomph" in the upper RPM range. Thanks for the help guys.
Edit: Oh, and should I be buying "stud mount" rocker arms? Thanks.
90
Michigan insane asylum
Nov 27, 2006
  • Nov 27, 2006
i use ford racing roller rockers...
91ghp5.0
42
Somewhere
Nov 27, 2006
  • Nov 27, 2006
There are so many to choose from. stud, shaft, pedestal mount. i dont know which one!
also...do E7's have inline or canted valves?
woodyy24
290
illinois
Nov 27, 2006
  • Nov 27, 2006
your going to need pedestal mount for E7s
edit: i happen to have a spare set of 1.6s with shims.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Nov 27, 2006
  • Nov 27, 2006
1.7's no fit with cam and stock heads without notching piston.
91ghp5.0
42
Somewhere
Nov 27, 2006
  • Nov 27, 2006
that's why i dont have stock pistons
TRW's in the new shortblock.
modusmortis
54
  • Nov 27, 2006
stud mounts on the e7 heads.
You have inline valves on the e7 heads. A common example of a canted valve design would be the trick flow twisted wedge heads. Just compare a pic of the two and it should be pretty easy to see.
91ghp5.0
42
Somewhere
Nov 27, 2006
  • Nov 27, 2006
Gotcha, that makes sense. Thanks!
3/8'' studs?
mattmcdan
176
Okeechobee, Florida
Nov 27, 2006
  • Nov 27, 2006
e7 heads do NOT have stud mount rocker arms, I repeat DO NOT have stud mount rockers, they are pedestal style.
woodyy24
290
illinois
Nov 28, 2006
#10
  • Nov 28, 2006
  • #10
NO there NOT studs, their pedestal mount (bolt on)
Custom tune?
  • Nostang25
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 17, 2025
FastDriver
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Front control arms
  • Bronco Bart
  • Dec 28, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2025
limp
