what i meant by that was, have you checked to make sure that no plug gaps have been closed. to see if a piston came up & hit the bottom of a spark plug
You know it's surprising how often this happens. We have seen quite a few guys with stock bottom ends slap the ground strap with a piston after hitting the rev limiter. These guys had their rev limiter set higher than normal (6200-6400). I think these factory CP rods are prone to stretch at higher RPM's. On a few, the piston hit hard enough to push the ground strap into the porcelain insulator, breaking the insulator.
