anyone know if this works i gues its called the darkwolf mod? i dunno but i have a full bbk and someone told me to rotate it and i will get more power if you can help i app.
<---rysred96gtSilverBullit99 said:This mod will only make a difference if you have a cold air intake that goes into the fender. The reasoning is that the air coming in has to make a serious bend before it enters the MAF and the air is metered incorrectly. So if you turn the MAF 90 deg it will cause the reading to go leaner than before.
I did the mod and dyno'd it. At peak it was 10hp but in other areas on the graph it was a lot more.
Jim
now im debating on putting it back on. i have an open element under the hood right now. should i go back to cold air with darkwolf i guess?
