- Jul 7, 2003
- 254
- 0
- 16
I did the swap today. I jacked my car up got under it and started to look for the drain holes and what not and got pissed very quicky. So I took it to a Mobil center. Man they got oil everywere under my filter, they didnt clean it at all. Then they put the transmisson oil in (TR3650) and they used all 4 quarts of Royal Purple. From what I been told it takes about 3.2-3.5 quarts and if u fill it to the recommended it sould come out the fill hole. Well the guy said he could stick his finger in there and touch the oil so its a bit low. Low with 4 quarts in it. Then he did the rearend and put about 2.25 quarts in it.
Im abit dissappointed, for $200($95 labor + $100 oils/Filter) the transmission doesnt shift any better and the clunk is sill there. As for the Dyno tested 10 hp at the wheels I dont think that was totally true. I think Royal Purple payed the HP TV shows to put out those results. I could just be hard to please.
6 qts Royal Purple 5-20w
4 qts Royal Purple Sync-Max
2.25 qts RP Gear-max
1 bottle of royal purple radiator additive (Do I just put this in my overflow as is?)
THE NEW FRPP OIL FILTER (Which I watched the guy put on with old oil on the seal!!!!!!)
