RPM set point
  • Thread starter Thread starter crazyhorse89
  • Start date Start date Dec 13, 2005
crazyhorse89
30
Bay City, TX
Dec 13, 2005
  • Dec 13, 2005
Have an 89 GT with minor add ons, bbk cold air, msd blaster coil, msd cap and rotor, msd 8.5 wires, no smog pump 3:55's, what should my rpm idle be at, i have it at 900 right now, anyone have a better idea on what it should be on? Thanks in advance
HISSIN50
34
129
Dec 13, 2005
  • Dec 13, 2005
Welcome to the board!
Stock is 625-675 RPM IIRC. Anywhere between there and 900 RPM is probably fine - it kinda depends upon each individual car. Most guys start messing with the idle setting to accomdate cams.
Good luck.
crazyhorse89
30
Bay City, TX
Dec 13, 2005
  • Dec 13, 2005
Thanks for the welcome and i am gonna lower it to about 750-800 and see how it drives and reacts, has anyone run an msd 6a or 6al box on a stock 5.0? If so what are the good and bad things about it?
Black1987Stang
1,422
Jersey Shore
Dec 13, 2005
  • Dec 13, 2005
Nothing wrong with the MSD box, i just heard u cant run stock non spiral core wires or something. But anytime you mess with the idle you need to reset ur tps
crazyhorse89
30
Bay City, TX
Dec 13, 2005
  • Dec 13, 2005
Thanks for the tps headsup, i do have the spiral wound wires from msd, i was just wondering if the 6a box was worth the money, as far as an added mod to my stock stang?
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Dec 13, 2005
  • Dec 13, 2005
Ford IAC's go bad a lot.
First, I would clean out the IAC solonoid and throttle body. Then disconnect the AIC and set the idle using the throttle stop set screw, then, shut it off, reconnect the IAC and restart the motor, this should help. Sometimes, removing the batter cable and resetting the computer helps after the throttle has been set. This is called the Ford Idle Reset Procedure. If this fails, then resort to replacing the solonoid.
HISSIN50
34
129
Dec 14, 2005
  • Dec 14, 2005
Here is some info on cleaning and resetting the idle.
Good luck.
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Engine Running like crap :(
  • justadude07
  • Sep 27, 2025
Fox 5.0 Mustang Tech Oct 19, 2025
DadLife0724
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
