  • 1994 - 1995 Specific Tech
rubbing brakes?
  • Thread starter Thread starter Mustangless
  • Start date Start date May 22, 2006
Mustangless
903
home
May 22, 2006
  • May 22, 2006
Are the brakes supposed to drag any? My front wheels (not sure about back) are dragging a little. With the front lifted and spinning wheels by hand, it will make a slight grinding noise. They also will not spin much at all.
At first, i thought it was because the rotors had a little rust on them. Now it is all rubbed off and it still does it.
It is not rubbing bad, but it is rubbing.
I think this is normal, just making sure.
Methodical
1,192
11
59
Clinton, MD
May 22, 2006
  • May 22, 2006
It could be the wheel bearings going bad. The brake pads will ride on the rotor but the wheel should spin freely. When you spun the wheel how many times did it turn?
S/CBlack95GT
2,018
Tampa Palms, FL
May 22, 2006
  • May 22, 2006
That is totally normal. You only have to worry if they drag heavily and you have to put effort into turning the wheel.
Mustangless
903
home
May 23, 2006
  • May 23, 2006
I don't spin it real hard, but it only goes like 1/2 a turn. But if I get it up to speed it will go around 1 or 2 times.
1TallMF
955
Montreal
May 23, 2006
  • May 23, 2006
Sounds okay to me
LoudToy958
435
Bremerton, WA
May 23, 2006
  • May 23, 2006
Normal, mine does the same thing. As long as you can move the rotor by hand, you should be just fine.
Methodical
1,192
11
59
Clinton, MD
May 23, 2006
  • May 23, 2006
Yeah you're cool
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
