Running Hot after new TFS intake install???
Hey red,
Did you trim the coolant gasket around the coolant ports. The design is so, where it protrudes into the coolant passages at the end of the heads.
Basically, did you trim anywhere on the gasket before you installed it? Did you install a FPP-1250?
If you could find out the part number, that would be beneficial. Just back track how you got the gasket and where you got it from:nice:
The 5.0L lower intake gaskets that I am aware of have a coolant port protrusion that 'rides' over the coolant passages.
Does anyone have a picture readily available for redfox91 to see?:)
It can obstruct flow fairly significantly. It is designed for 351 heads if I recall...
just a thought- i recently replaced my water temp sending unit to a new one from napa.... it was WAY off! it read over 50 degrees hotter than my old one...i changed it back to my old one, and it read perfect again so i had a bad sending unit.
