thinking about getting rid of my smog pump s*it i live in Vancouver WA and i know the smog restrictions differ from all over just wanted to know if anyone has tried it and if it still passes emissions or not. thanks all MERRY X_MAS
In Washington State, they do not do a visual inspection, it just has to pass the tail pipe sniff test. That being said if it fails the test and you have to take it to an authorized emissions repair shop, there is no cost limit on installing all of the correct smog equipment for the year/make/model. Or you can re-install the missing equipment yourself and take it back through for a re-test. By the book, it is both a Federal and State crime to tamper with or remove emissions equipment.
Do you still have the OEM cats?
The older converters (2-way) requore the use of the smog pump to properly "convert" the byproducts of combustion into less harmful gasses. Removing the smog pump but leaving the cats is not recommended.
Newer converters (3-way) do not require the use of a smog pump, so that's why cars these days don't have them. If you have these types of cats retrofitted, you may not need the pump.
Technically, removing any part of the smog system is an instant fail. It depends on how strict your state is and how good the inspector is at noticing such things.
So for instance, would buying a new catted BBK mid pipe feature 3-way converters? I'd love to get rid of my stinky exhaust, but with P heads I can't use a smog pump.
