running wayy to cold
  • Thread starter Thread starter D347643
  • Start date Start date Mar 6, 2004
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Mar 6, 2004
  • Mar 6, 2004
ok i have a 3 core 3 row rad in my car with an elec fan from a mk7, so i figure my cooling system is pretty well set up. The prob is i never get to even use my fan cause my car barely hits 155 driving for like 20 min with a 5 min warm up. I thought my thermistat was stuck open so i went and got a brand new one (stock 195 degree) and it still takes forever. Is it possible that my cooling system is too much for my engine? i have pretty much all trick flow stuff, heads,intake,cam etc. i dont understand why it wont get up to operating temp, what am i missing here?
thanks,
Drew
D
dragstang88
29
  • Mar 6, 2004
are you using the stock or aftermarket gauge...may just be the sender/gauge is on the way out.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 6, 2004
  • Mar 6, 2004
Drew - get a thermometer, a pan full of coolant (water/antifreeze mix) and plop your 195F t'stat in the pan on the cook top. Bring the temp. up slowly while watching the t'stat. Verify that it's opening when it should. It should start opening somewhere in the 193F-196F range and should open all the way by no higher than 197-198F. If it's not working correctly, get another one and test it the same way before you install it. The t'stat is there to control temp - it shouldn't matter how big your radiator is; if you have mega cooling capacity, the t'stat will open just a little and let a little 'cooled' coolant in and should control the temp right at 195F. And like the previous poster said, all this assumes that you've got an accurate gauge/sender (not factory) to measure with. Are there any other cooling system mods we need to know about? Have you bypassed anything? How is your fan controlled?
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Mar 6, 2004
  • Mar 6, 2004
my fan is controlled by a probe but i unplugged it and i have it on a switch, i also have a digital water temp gauge inaddition the the stock one.
Drew
Engine Which cooling part first?
  • Dontknowchit
  • May 8, 2025
Fox 5.0 Mustang Tech May 15, 2025
90trunk
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
