Saving Gas
  • Thread starter Thread starter malik641
  • Start date Start date Nov 3, 2005
First Prev 2 of 2
malik641
53
South Florida
Nov 4, 2005
#21
  • Nov 4, 2005
  • #21
iwashmycar said:
airplane fuel...i dont know...unless its like acetone
Ive been putting in two ounces of acetone in a full tank and have gained over 40 extra miles to my tank (mostly highway). But it works IMO. I can only prove the mileage, but I think there are other advantages, such as better idle and whatnot
I am still doin it and will continue to.
adam
Acetone like off the shelf nail cleaner type of acetone???
Some interesting info I found:
Acetone
Does the mixture create a higher combustion point? Is the combustion greater?
Look Its Aaron
Your car looks like it came straight from Mexico.
2,634
Fontana, Cali
Nov 4, 2005
#22
  • Nov 4, 2005
  • #22
Read this link for info. I posted it before.
http://www.pureenergysystems.com/news/2005/03/17/6900069_Acetone/
malik641
53
South Florida
Nov 5, 2005
#23
  • Nov 5, 2005
  • #23
Thanks Aaron Great info!
I will DEFINITELY try this starting tonight
I remember learning about liquid tensile strength in chemistry. Like the example in my text book where water has enough tensile strength to let a pin rest on it if placed carefully. If you add one drop of soap, the water loses its tensile strength and the pin will sink.
Great idea with the acetone use in motors!
malik641
53
South Florida
Mar 20, 2006
#24
  • Mar 20, 2006
  • #24
I know it's been a while, but I just wanna follow up on this.
I did try this and ever since I've been using acetone and will NEVER stop using it.
I tried a few tanks without it afterwards and my MPG decreased dramatically. Also, I took a trip to FL from Jersey with the acetone and I got a WHOPPING 27 MPG on average!!!!!!! riDICulous!!!!
Just wanted to let everyone know my new love for acetone
M
Mark89coupe
206
#25
  • Mar 21, 2006
  • #25
Are you still using 2 oz every tank? Why 2 oz? not more or less?
mississauga5.0
27
Mississauga/ Toronto Canada
Mar 21, 2006
#26
  • Mar 21, 2006
  • #26
really interesting stuff.
i will be trying it today. i have been getting crusified at the tank and my beater has no plates.
ninety15.0
1,336
#27
  • Mar 21, 2006
  • #27
Just a quick note....tensile strength is not the proper term here. Tensile strength refers to a materials strength when it is pulled apart. for example take a pencil and pull the two ends in the opposite direction....quite difficult and way easier that just snapping it in half. your thinkin surface tension....very different. Im also interested in people's calculated results from using acetone....i wouldnt mind some additional milage either!!
vristang
4,933
101
124
Seattle
Mar 21, 2006
#28
  • Mar 21, 2006
  • #28
I used acetone in various concentrations for several tanks and saw no improvement in mpg.
For 11 tanks I alternated acetone and non-acetone tanks. The three highest fuel economies I registered during this time were non acetone. My non-acetone average for these tanks was 1.3 mpg better.
While my driving cycles were not exactly the same for any 2 tanks, they were close enough to allow comparison of average economy. The one road trip I took during this time was Acetone there (16.3mpg), non-Acetone back (20.3mpg). This was at 3oz per gallon.
I have been suspicious that compression ratio will have a major affect on how well economy responds to acetone. My ratio is less than 9:1.
I am sure other factors will have an impact as well.
jason
8950HO
658
#29
  • Mar 21, 2006
  • #29
Throw in a can of Molyslip E,(Canada),or Mr.Moly,(USA) to further reduce internal engine friction..No **** it works.
9
90bronconate
124
Phoenix, AZ
Mar 21, 2006
#30
  • Mar 21, 2006
  • #30
vristang said:
This was at 3oz per gallon...
do you mean 3oz per tank? because the article reccomended 1 to 3 oz per 10 gallons. any more and a decrease in mileage would be observed as acetone increases the octane rating.
malik641
53
South Florida
Mar 22, 2006
#31
  • Mar 22, 2006
  • #31
Yes, I was thinking surface tension....my bad.
Thanks
Look Its Aaron
2,634
Fontana, Cali
Mar 22, 2006
#32
  • Mar 22, 2006
  • #32
hmmm...
9
90bronconate
124
Phoenix, AZ
Mar 22, 2006
#33
  • Mar 22, 2006
  • #33
well since i calculate my mileage religiously, i'll try it and report back after 5 fill-ups with any increases/decreases
mississauga5.0
27
Mar 25, 2006
#34
  • Mar 25, 2006
  • #34
just finished pouring it in
my last reply didnt get posted so i dunno. ill try again
anyways i just got back from home depot and canadian tire. bought a small glass measuring cup and a metal canister of acetone. it did not specify how pure it was but im trusting it is pure enough.
i poured roughly 3 -4 ounces into a full tank of gas. a lot spilled so i re - measured maybe 1 ounce.
make sure and use the attachment from a portable gas container (which im planning next time if this works) it looks like it could screw right onto the acetone container.
so ill update you guys on the diff. if any.
btw. i read one of these threads mentioning that if the gas stations in my area have ethonal in the gas then there will be negligable results. someone please confirm. thank you.
lates and id like to quickly mention i like owning 3 series Bmrs
M
Mark89coupe
206
#35
  • Apr 21, 2006
  • #35
Any update? I switched from 93 octaine to 89 put half a bottle of sea foam- I went from 20mpg combined to 21.5 combined. Im gona try the acetone next tank.
9
90bronconate
124
Phoenix, AZ
Apr 21, 2006
#36
  • Apr 21, 2006
  • #36
ok, here's my update.
the only time i drive is to work which is 48 miles round trip(about 85% highway). i go to ASU, so i ride a bike everywhere else.
my average mpg without acetone was 21.4 on 5 consecutive tanks
my average mpg with acetone was 24.15. 2 tanks with an oz/gal ratio of .13(2 oz per 15.4 gal) and 1 tank with a ratio of .1(about 1.5 oz per gal). with the .1 ratio, i got 23.3 mpg. i'm currently on my 2nd tank of the .1 ratio, so we'll see how that goes.
in my opinion, it deffinitely works. i've seen an improvement of almost 3 mpg.
- edit - i have 2.73 gears and a completely stock engine.
First Prev 2 of 2
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
  • Mindseye007
  • Aug 16, 2026
Mindseye007
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
