School me on Torque boxes
  • Thread starter Thread starter Roland69
  • Start date Start date Mar 28, 2007
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 28, 2007
  • Mar 28, 2007
Don't know alot about what the big deal is on beefing them up and what happen's if you don't. Pics, opinions are welcome
86nu
94
Birmingham, Al
Mar 29, 2007
  • Mar 29, 2007
No pictures, but they reinforce the areas where the control arms mount to. If you race your car, over time you will rip the mounts to pieces/out and be screwed. It doesnt take but a few hrs to install reassemble the car. Well worth the money, a good set can be had for about 100 bucks or so.
P
PRO50SC
1,012
Olney, Maryland
Mar 29, 2007
  • Mar 29, 2007
This might help a lil.
http://forums.stangnet.com/showthread.php?t=688785
Maryland Stang
1,656
30
39
Greenville, NC
Mar 29, 2007
  • Mar 29, 2007
I put uppers and lowers on mine despite the fact that I probably have neither the power or the traction to damage the TBs without them. I've seen pics of damaged boxes and I don't want to go down that route.
I've also been getting the car prepped over the last couple of years for the HCI project that I will start within a month or so.
W
WilwoodFiveO
108
VA
Mar 29, 2007
  • Mar 29, 2007
Im looking at buying torque boxes too. I have only heard good things about wild rides race cars. The combo pack is for 185 bucksi think thats a good deal for uppers and lowers from them. also they say the time for lowers is 2.5 hours is that true?? i read in PRO50SC that it only took him about an hour, but whatever i need to get these in.
do you think i should order?
http://www.wildridesracecars.com/chassis3.html
- Cody -
Stroker5.0
12
Baltimore Highlands Maryland
Mar 29, 2007
  • Mar 29, 2007
Beefing up your torque boxes is a good idea when you can afford it but not necessarilly right away. The battle boxes and others will work or you can do like I did and have a good chassis shop weld on steel plates, basically that is what these kits are, just prefabricated and cut plates.
What ever you do. If your car is a daily driver. DO NOT install any aftermarket lower or upper control arms with solid bushings, sperhical, heim etc.. Use Polyurethane bushing arms. The solud bushing arms such as Southsides (basically a bolt in a steel sleeve) will tear up your torque boxes. And then you will have to get them welded back up. This happened to me. Solid bushinged or spherical bushing arms are only good for drag racing. The constant motion of a solid axle car constantly going over bumps, turning into and on road service imperfections, speed bumbs etc. puts a were on these type of bushings and their mounting surface ie: the torque box
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 29, 2007
  • Mar 29, 2007
so just some control arms with normal polly bushings would be fine for 95% street and maby 5% track...and the torque boxes are a good idea to do while I am in there.
smr
167
Nor*Cal (Vacaville)
Apr 3, 2007
  • Apr 3, 2007
torque boxes reinforcements are a must...the previous owner of my car tore the upper drivers side box a little and the upper passenger side box was compeltely ripped off car. I now have the wilde rides racecar box kit and it went in great..took us some time on a lfit though sense my boxes were so far gone and had to be straightened and realigned before installing new kit.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Opinions on a possible project car w/ pics
  • Teen'93stang5.0
  • Mar 29, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Mar 30, 2026
Teen'93stang5.0
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
