Seafoam is teh *****!
  • Thread starter Thread starter MidnightGT
  • Start date Start date Jul 6, 2005
  • 12
  • 13
  • 14
  • 15
  • 16
  • 42
First Prev 14 of 42 Next Last
ponysarepretty
578
#261
  • Nov 21, 2005
  • #261
Up Up Up
M
MAXX RS4
83
#262
  • Nov 21, 2005
  • #262
sgarlic said:
Guess that still makes me the only person who had a negative affect from running seafoam. My wife's Jeep did the whole smoking thing, which judging by the ingredients has nothing to do with burning off carbon, but more like burning the oil they add in. I did 1/3 in tank, 1/3 in crankcase, 1/3 in intake.. sat 10-15 minutes, etc.
Smells like I have no catalytic converter on it anymore, now has hesitation issues, and has hard starts when cold.. never had these problems before I ran it. Maybe I got a bad batch.
Actually, a few pages prior I posted a question. I asked if anyone has ever heard of seafoam burning up the cats. After using it my car smelt (and still does) smell like an uncatted car. Is it possible?
But I'm pretty sure the white smoke is carbon burning off. If you burn the seafoam alone (i tested with a torch) it creates no smoke. When dense carbon burns it creates light white smoke. There's most likely some gummed up oil buildup that's burning off with it as well.
Fast02
239
#263
  • Nov 21, 2005
  • #263
From Sea Foams website:
SEA FOAM MOTOR TREATMENT for Gas Engine Applications
100% Pure Petroleum
Use in All Engines in All Seasons
2 Cycle, 4 Cycle, and Diesels
Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
Cleans fuel injectors
Cleans carburetor jets
Cleans carbon
Stabilizes fuels
Upper cylinder lube
Removes moisture in fuel
De-icer
Frees sticky lifters
Frees sticky rings
Removes moisture in oil
Cleans P.C.V. systems
Cleans catalytic converter odors
Oxygen sensor safe
How Many Mechanics Use SEA FOAM
In Tune-Up of 4 Cycle Gasoline Carbureted or Fuel Injected Engines
Autos, Trucks, and Tractors
With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area.
FUEL TANK, CARBURETOR, INJECTION and OIL CRANKCASE.
For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
A 100% pure petroleum product for use in all gasoline and diesel type engines, both 2 and 4 cycle. OXYGEN SENSOR SAFE.
Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY.
Removes moisture from oil crankcases and fuel tanks.
Stabilizes and conditions fuels. Use for engine storage.
Cure hesitations, stalls, pings and rough idle due to carbon buildup.
Helps pass emissions test. EPA Registered.
When Used Thru Injection or Carburetor
Cleans carbon build up
Cleans intake valves and pistons
Gives smoother idle
Cures hesitations and pings
Restores power and pickup
With warm engine running, SLOWLY poor 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
For use in injector cleaning machines, use 50% SEA FOAM and 50% fuel.
Fill diesel filters with SEA FOAM to clean injectors fast.
When Added to Crankcase (Oil)
Frees sticky lifters and rings
Increases R.P.M.'s vacuum and compression
Cleans dirty parts
Removes moisture
Cleans PCV valve systems
One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
When Added to Fuel Tank
Cleans fuel injectors and carburetor jets
Cleans carbon as you drive
Lubricates upper cylinders
De-ices and removes moisture
Diesel full conditioner and anti gel
Stabilizes fuel
One pint treats 8-25 gallons of fuel (average 1 ounce per gallon).
In Injector Cleaning Machines
Add a 50/50 blend of fuel and SEA FOAM into injector cleaning machine. Run directly through the fuel rails to clean injectors fast. Add SEA FOAM to your fuel tank to clean injectors as you drive.
40th GT
916
Lawrenceville, GA
Nov 21, 2005
#264
  • Nov 21, 2005
  • #264
Seafoam is supposed to be safe for cat-converters. It even says so on the bottle.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Nov 21, 2005
#265
  • Nov 21, 2005
  • #265
I need to use some of this.. never done it before and i've got 53k on the car
joshheat25
871
Delaware
Nov 21, 2005
#266
  • Nov 21, 2005
  • #266
I Haven't Even used this Stuff and it is The **** Already man! I am going to have to try this! I will have to take some pics as well!
97GTAP
85
Seattle
Nov 21, 2005
#267
  • Nov 21, 2005
  • #267
Somebody make this a sticky ...This thread will never die.
joshheat25
871
Delaware
Nov 22, 2005
#268
  • Nov 22, 2005
  • #268
I Went down to the auto Parts store and Bought two cans of teh seafoam and I have a Question?? Should I change My Oil If I put it in through the PCV Valve?? I know I should If I put it directly In the Crank Case but what about through pcv?? thanx
M
MAXX RS4
83
#269
  • Nov 22, 2005
  • #269
I didn't.. And I've done about 3k mile since then. My oil looks new, doesn't smell weird, and everything seems just right..
joshheat25
871
Delaware
Nov 22, 2005
#270
  • Nov 22, 2005
  • #270
okay Thanx!
ponysarepretty
578
#271
  • Nov 22, 2005
  • #271
The PCV just vents the oil pressure, there won't be any that goes into the crankcase again. And be quite clear, you don't put it INTO the PCV, the PCV will suck it out. If you have to force feed it, yoru doing it wrong proabbly
And for the oil, you should probably wait a couple hundred miles before changing to let the stuff do its work.
ultrashock2112
100
Vancouver, Canada
Nov 22, 2005
#272
  • Nov 22, 2005
  • #272
Can someone send me a can of this stuff?? I can't find it anywhere in Canada!! crapola
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 22, 2005
#273
  • Nov 22, 2005
  • #273
The Seafoam website has a dealer search feature...
joshheat25
871
Delaware
Nov 23, 2005
#274
  • Nov 23, 2005
  • #274
I just put teh Seafoam in and after done putting it in i gave the engines a couple revs from under the hood and saw some smoke coming up from the engine bay?? could this mean I have a leak between the exhaust manifold and the x pipe? Because I have fixed that area a couple of times! but here in another 10 minutes I am going to take her for a test drive and post up!
joshheat25
871
Delaware
Nov 23, 2005
#275
  • Nov 23, 2005
  • #275
Okay It Smoked ALOT! JESUS but as far as performance ahh didn't notice anything major yet it runs a little smoother! but not much
joshheat25
871
Delaware
Nov 25, 2005
#276
  • Nov 25, 2005
  • #276
Pics! Hey Seafoam has to go on! it will never die!
40th GT
916
Lawrenceville, GA
Nov 25, 2005
#277
  • Nov 25, 2005
  • #277
Yes.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 25, 2005
#278
  • Nov 25, 2005
  • #278
Seafoam has the added benefit of enabling you to detect exhaust leaks
9,025 page views on this legendary thread...
timeless2
Vi Veri Veni Versum Vicus Vici
Admin Dude
202
154
the Shadow Gallery
Nov 25, 2005
#279
  • Nov 25, 2005
  • #279
I even pointed some 5.0 guys to this thread today.
joshheat25
871
Delaware
Nov 25, 2005
#280
  • Nov 25, 2005
  • #280
Yea I fixed it! Seafoam is alright!
  • 12
  • 13
  • 14
  • 15
  • 16
  • 42
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Eastern North Carolina Autocross Events!
  • Warhorse Racing
  • Feb 23, 2026
  • Regional Forums and Event Information
Regional Forums and Event Information Feb 23, 2026
Warhorse Racing
  • Locked
93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2025
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
