- Oct 9, 2003
- 968
- 1
- 17
Since I've installed the TwEECer, my car will most times enter KOEO on it's own once the ignition is turned to on. The fan will run low, then high, then off. The pump also runs for a sec, then off. Then codes start flashing. I even had it enter KOER on its own after starting the car.
I've checked the wiring and the STI input is not jumpered. I used a multimeter to measure the resistance between the STI input and ground. It was about 4K ohms. I then removed the ECM and measured again, and it was infinity (no short).
Has anyone ever heard of this / had it happen?
Would someone PLEASE measure the resistance between the STI input and ground with the car and ignition off? It shouldn't take but a minute. The STI input is the connector with only 1 wire in it where you jumper it to the other 6 pin connector when you want to start a KOEO test.
Thanks,
Rick
Thanks,
Rick
