Seting Initial Timing w/Chip
Xticee
38
I just finished a cam swap (comp cams xe270hr) & new HB and need clarification on setting initial timing. The car is running with a Hypertech chip (cause it came w/it) and I set base timing w/spout out to about 12*, which is way down from the 18* or so it was at originally. Anyhow, it idles great & really runs well, but pings a bit under hard accel. So I'll back it down to 10* and see, but before I mess with it too much, should I remove the chip before setting base timing?
Thanks,
Jay
Hello Jay
That is a question than can be tough to give an accurate answer :(
You really don't know where the dizzy was when the chip was burned :shrug:
If it was at 10 ... then every additional degree you add in with the dizzy
will be a global adder to whatever the Pro Tuner did to the spark tables.
Well ... now that I looked at what I just typed :eek:
It works the same no matter where the dizzy was when the chip was
burned :)
Never the less ... you get the idea ... I hope :D
I'm trying to get across :rlaugh:
Now ... If it pings with the dizzy at 12
Then you basically got two choices
1 Back down on the spark
2 Up the octane count
Well ... I guess you could do both :scratch:
I mean ... Maybe he had the tune set to be aggressive
and
He was running good gas to obtain the most spark possible :shrug:
I'll confess to using that method ;)
Grady
Thanks Grady,
You forgot one more option....only drive in cooler, less humid weather. 56* this morning and it ran like a champ! In fact I added a bit of timing cause it was feeling kinda sluggish at 12*. I'll see how it does throughout the day with the warming temps. The tank has 89 octane in it, so once I burn through that I'll step up to 93.:nice:
Guess it's gonna be a crap shoot as long as I have that chip in and am having to adjust timing w/the dizzy. Hopefully not for too much longer as I plan on stepping up to a tweecer. I just wanted to get it running decent, get on a dyno and get a good baseline for future comparisons.
Jay
I know what you mean Jay :)
If you decide to go with the Tweecer and the self tune thing :nice:
which btw
I highly reccommend cause it has worked out pretty good for me :spot:
I'd skip the dyno ... for a while :Word:
I'd get familiar with tuning your Stang in Closed AND Open Loop ;)
You then use the street to get to like 97 or 98% on a perfect tune :D
That way ... when you go to the dyno ............
All you gotta do is + or - a little spark or fuel to make maximum power :banana:
Grady
Skipping the dyno is probably good advice, but the wait is killing me! Although it would put me closer to having the $$$ for the Tweecer & wideband.:rolleyes: You've definitely given me something to think about. Thanks again for the help & direction,
Jay
