Shelby front end drop
  • Thread starter Thread starter mtymo_
  • Start date Start date May 5, 2007
M
mtymo_
  • May 5, 2007
Hello Everyone,
I just completed a granada disc swap, the shelby upper control arm drop and cut a 1/2 a coil out of the front spring on a 66 Mustang. Now I need to drop the back 1-2" to match the front. My question is the proper measuring locations to determine a level point. I can be fooled easy by an optical illustions and only want to do it once. Do you measure from the top of the wheel lips, a level on the door sill or ????????.
Thanks......mm
BornInAFord
199
Bend, OR 97701
May 5, 2007
  • May 5, 2007
IIRC, Ford made it easy on us in that the wheel lips are the same height front and back. Otherwise, in a nearly level place like a garage, just measure from the ground to the bottom of the rocker just behind the front tire well and just in front of the rear tire well. That should give you a good idea of whether the car is level.
Daniel
HistoricMustang
2,359
Confederate States of America
May 6, 2007
  • May 6, 2007
You may want to stick that nose down just a bit.
At Interstate speeds she is going to lift producing a "boat in water" appearance.
Happy Motoring!
HistoricMustang
www.historicmustang.com
zookeeper
3,415
63
109
Rogue River, Oregon
May 6, 2007
  • May 6, 2007
I agree, but I'm a huge believer in the old "stand back and look at the car" method of determining stance. Use a tape to make it level side-to-side, but then make it look appealing to you by dropping the rear until you like what you see.
Jester67
908
TN
May 6, 2007
  • May 6, 2007
How old are the front coils if they are new you might want to let them settle a bit before you try to set finnal height
M
mtymo_
  • May 6, 2007
Thanks
All good advice, thanks guys...........mm
Height of wheel well opening over the tires, front and rear, and adding clearance for 17x9 wheels up front
  • Blue Thunder
  • May 21, 2024
1974 - 1978 Mustang II Talk & Tech May 21, 2024
LILCBRA
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
