shift kit for auto 90' LX
  • Thread starter Thread starter Stallion96Vert
  • Start date Start date Jun 17, 2005
Stallion96Vert
14
  • Jun 17, 2005
My brother has a 90' LK vert that is an automatic and he would like to make it alil faster. I thought one of the best things to do was to put in a shift kit, but im not sure which one to use and where to find it. Anyone know of a good one to use and where to find it?
Thanks,
Shane.
MrKwik
1,008
Kansas City, Kansas
Jun 17, 2005
  • Jun 17, 2005
Put a gear in it. That will really wake up an AOD car. The only shift kit that I think would make a real difference are the ones that change the shift pattern so you dont have to do the one-dee-one shuffle. Not sure whats all involved in those though.
D
Deleted member 87397
Jun 17, 2005
  • Jun 17, 2005
TransGo or Baumann Engineering. Do some rearend gears along with it and you'll notice a diff.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 17, 2005
  • Jun 17, 2005
First mod for any Mustang should be Gears! Worry about that trany later.
SilverFoxbody
149
  • Jun 17, 2005
Top 5 mods in no particular order
1) gears
2) shift kit
3) converter
4) heads
5) exhaust
If you have a 5 speed, you get to save some cash and eliminate 2 items.
crazypete
All my crevices are greased.
Oct 22, 2004
930
Arlington, MA
Jun 17, 2005
  • Jun 17, 2005
If you go for transgo on the shift kit, make super sure to leave out the 3-4 shift valve modifications.....well, unless you like getting dumped into OD while trying to accelerate. They say it's a "feature" of their kits but I think anyone that drops into OD while at WOT is asking for breakage. You can feel the hit.
ramjetlx
212
Honolulu, Hawaii
Jun 17, 2005
  • Jun 17, 2005
Yep, thats what happened to my Trashgo while using nitrous. Burned a new OD band after one month. Now I just have 3 gears, but thats better for me at the track, but not on gas while cruising the highway. Shifting into OD really messes up your ET. Stay away from Trashgo!!!
2KsilverGT
354
Collinsville Va
Jun 17, 2005
  • Jun 17, 2005
I have a B&M shift improver kit in my 93 aod. Works pretty good and I bought it for 25 bucks summit has them for 28. inexpensive and works really well
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jun 17, 2005
  • Jun 17, 2005
Baumann Engineering shift kit all the way, then get a nice stall
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 17, 2005
#10
  • Jun 17, 2005
  • #10
How old is the tranny and how many miles. If it's the original 15 year old tranny I would just keep the fluid clean (flush), maby a new filter and add a good trans cooler such as the B&M Supercooler. It seems when people put shift kits on old AOD(E)s it pushes them over the edge. Maby not right away but sooner more than later. I'd do a stall before a shift kit. You might be suprised how a trans cooler improves shift quality. Oh yeah, if no gear I wouldn't even be considering anything else.
M
Mopar1
61
Shelton, WA
Jun 18, 2005
#11
  • Jun 18, 2005
  • #11
Eh, I just stuck a Lentech VB in mine and forgot about it.
Stallion96Vert
14
#12
  • Jun 20, 2005
  • #12
Your all saying to get a gear. I have been reading that in my brothers car the rear end should be a 2.73 ratio. But someone else is telling me it should be a 3.08 or a 3.27. Do any of you know what should be in this car? And is there a way to look at maybe the sticker on the inside door to find out?
Also, what ratio do you guys suggest? 3.73, 4.10?
Thanks,
Shane.
crazypete
Oct 22, 2004
930
Arlington, MA
Jun 20, 2005
#13
  • Jun 20, 2005
  • #13
Look at the tag on the axle pumpkin cover. Should have something something 73 or something something 08.
They need to get switched either way to a nice heathy 4.10. I used to have 3.73's and I found them to be not enough. Lots of pep but not enough to whip you into the seat. I chose to go with 4.56's and wow. That really slams you into the seat. Pulls about 3k on the highway at 80mph though but oil and coolant temps look ok so I figure the little 302's can take it.
gcwh02
515
pottstown, PA
Jun 20, 2005
#14
  • Jun 20, 2005
  • #14
hey i have a shift kit and 2500 stall in mine, i want to make the trans. better, what else can i do, would a lentech manual valve body be a good investment?
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Jun 20, 2005
#15
  • Jun 20, 2005
  • #15
gears will wake up the car like no tomorrow, it will make you use curse words in joy.....
I havent expierenced it yet, but my friend has an s trim mustang with 3.90s and he says of all the mods he does, he has new rearend, tranny work sc etc.
the gears made the BIGGEST difference on how much it throws you in the seat...
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
