  • 1994 - 1995 Specific Tech
shock removal q's
  • Thread starter Thread starter 94Five0
  • Start date Start date Dec 1, 2004
94Five0
Loose Colon
Dec 14, 2002
349
Birmingham, Alabama
Dec 1, 2004
  • Dec 1, 2004
jus picked up some illumina 5-ways from a good buddy an am anxious to put em on.. is there any secret to gettin them off?..i've got a basic craftsman set, wheel stands, an a floor jack..would prefer to not screw up anything..
chaos254
467
NJ
Dec 1, 2004
  • Dec 1, 2004
just did the shocks/struts in my 95 last week. The shocks are extremely easy, its just 2 bolts. One bolt is in the trunk and one underneath the car. You don't even need to jack the car up. The struts are more involved. I was doing the brakes as well so I just removed the rotors and could reach the 2 bolts pretty easily. Make sure you have a jack under the control arm before you take these 2 bolts out! Your gonna need a impact gun for the strut bolt but the other 3 bolts in the strut tower come out easy. It was my first time doing shocks/struts and it didn't take that long at all.
95Cobra302
394
Daytona Beach, FL
Dec 1, 2004
  • Dec 1, 2004
If I remember correctly, from the factory they are torqued to about 130-140 ft. lbs. So you better have an impact like he said.
slytherin
702
northeast ohio
Dec 1, 2004
  • Dec 1, 2004
It's relatively easy have an impact gun or 1/2 in drive ratchet and a breaker bar. A can of PB blaster or wd-40 would help too presoak all of the bolts the front strut bolts and nuts are big like a 22mm and 24mm socket will be needed to get them off.
N
Nagash01WS6
402
Deland, FL
Dec 1, 2004
  • Dec 1, 2004
You MUST support the a arm before unbolting the strut. I soaked everything in WD40 first, im sure it loosed a few things up.
Remove your calipers first, two 15mm bolts on the back of the spindle, and the caliper / pads will slide right off, hang them with a wire from somewhere. Then slide your rotor off the hub. Take a 1/4in socket and remove the abs sensor, and then the bracket. Then have at the strut bolts.
If I remember correctly... it is a 22mm and a 24mm socket for the strut -> spindle bolts as slytherin said. Just get a breaker bar and it will come right off. Remember to support the a-arm though. That is a must, otherwise you could be injured by the spring flinging everything around.
slytherin
702
northeast ohio
Dec 1, 2004
  • Dec 1, 2004
Oh definetly have that a arm supported I did my kit with a 3ton floorjack and the car on stands when you go to let the a arms down do it real slow. I had a buddy of mine take a spring to the thigh bone and almost broke his leg it was bruised for a month and he could barely walk for a few weeks. I had to push down farther on my a arms to get the springs out, the pressure was gone but just not enough room to pull them out.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 1, 2004
  • Dec 1, 2004
You will need an impact when removing the top strut bolt (15/16th) in the engine bay. Like mentioned remove the two 15mm caliper bolts. With the car on jack stands put the jack under the A arm. Jack it up a bit. Remove the top strut bolt in the engine bay. Now remove the lower strut bolts. That's about it really.
89 blue lx
1,936
FSU in tallahassee GO SEMINOLES!
Dec 1, 2004
  • Dec 1, 2004
this is the way i did mine over the summer and i also did it along with new pads and rotors it was fairly simple esp cuz i did my lowering springs so i had knowledge on how to do it already
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
P
Fox 17" Deep Dish Bullitts on Rear of Fox, 275/40/17?
  • pindude80
  • May 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2025
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
