Side Mount
JD1964
there is enough sticking out to grab on to
3,637
1,658
194
Maryland
My boom is too short, lol. Gotta do the side mount to get it in all the way..
Here's pics of the action
Prepping for intake
Torque it down
Ready to go..( I could care less about paint or bling)
Sizing up the entry
Will it make it?
Precarious!
Plan of attack approved. Set it back down for now.
Next trip I bolt on flywheel and clutch and ram that sucker in!!!
Nicely done. I've done that as well. I now have an extension made from square bar stock. I also have 400 lbs of tractor plates as base weights. Old cast iron heads make awesome base weights too. Cheap as hell from JY and they stack nicely. :)
Reactions: JD1964
Yeah my hoist is the cheapo 1 ton from harbor freight. With the boom set all out at the 1/4 ton lift limit, no way it would reach from the front. Even with side approach I had to drill extra holes in the boom to get the added reach. And when the assembled engine is up high, the sense of stress on the hoist fills the whole garage. (Slight flex and wobble). I just move it in very small increments to minimize the load swinging. One good thing on this hoist though is all 4 casters swivel. I can move it in from the side then coax it forward or back no problem.
Advice to my motor head brethren. If yur gonna get a cheapo hoist from harbor freight, spend the extra $70 and get the 2 ton model. The 1 ton ain't made for much more than transverse mounted 4 or 6 bangers. Don't even think about trying to pull a motor from a pickup truck with the lesser hoist. Not unless you remove rad support or entire front clip for that matter.
