Size of bolts needed for AOD to T5 swap?
wgpaintballer
49
well after gathering all the parts i ran down to my local ford dealership to pick up the bolts that are needed
trans to bellhousing
flywheel
and pressure plate
they had no clue what the sizes are or what ones i need... if anyone can help me out and tell me the sizes and how many i can use it will be very appreciated
flywheel bolts you can use the ones you took off of your AOD flexplate
pressure plate bolts and dowels you can buy in a ford racing kit from 50resto
trans to bell i'm not sure on the size, i got a trans with the bell still bolted on, but i can check for you the next time i crawl under there though
