my car is still at the tuners, so im not sure what the exact #'s are, but i will let you guys know tomarrow. from what i heard, im not too impressed.
so far he said he got 11 peak rwhp out of them. now im not sure what the gains are in other areas of the rpm range, hopefully high. not sure of the rwtq gain yet either, he is not done tuning it.
tuner is having some problems with the car running lean from 2000-3000 rpm's
he said he played with the fuel curve and some other things but said its still a bit lean. up top its fine
he said hes got a ton of fuel going to it too, not sure what he means by this. he also said that if he can get the bottem richened up ill pick up some more tq.
guys any ideas what might be causing this? also what is a good a/f range, what is too lean?
he said hes got a ton of fuel going to it too, not sure what he means by this. he also said that if he can get the bottem richened up ill pick up some more tq.guys any ideas what might be causing this? also what is a good a/f range, what is too lean?
and I'll still be on stock internals when I get the mongoose kit
