Small ignition question.
  • Thread starter Thread starter 69Rcode_Mach1
  • Start date Start date Aug 3, 2005
69Rcode_Mach1
1,473
Salt Lake City, Utah
Aug 3, 2005
  • Aug 3, 2005
Hey guys well good news I have a full ignition system now. With the new cap and rotor kit my 9mm wires work with my dist and looks great. Anyways I finally bought the final bit, the coil. I bought an MSD blaster 2 coil, it came with a ballast resistor, do I need to install this? I will be running the factory points ignition till later when I upgrade it. I really don't want to wire up this thing it won't look as neat, so if it can be avoided I would like to. What does that ballast resistor do anyways I am clueless?
brianj5600
1,964
Middle TN
Aug 3, 2005
  • Aug 3, 2005
Definately use it! It lowers voltage to the coil. They cost money and MSD would not include it if it was optional.
Max Power
1,774
St Paul
Aug 3, 2005
  • Aug 3, 2005
Are you using the factory ignition wire to the coil? If so, you may not need the ballast as the factory wire is a resistor wire.
Take a voltage reading and call MSD to see if it is in range for use without the ballast resistor.
My factory wire fir the same car as yours is only about 6.5 volts.
R
Riggs
151
Linden, NJ
Aug 3, 2005
  • Aug 3, 2005
I would drop the points and go with an electronic ignition but upgrade you can do.
69Rcode_Mach1
1,473
Aug 3, 2005
  • Aug 3, 2005
Yeah I plan to eventually drop the points down the road but not for now.
Max power that is what I was thinking, it is a resistor wire so I will take a reading and give msd a buzz.
C
For Sale Mint 1993 Calypso 5.0 Convertible
  • Chrispy62
  • Aug 22, 2026
Fox Body Mustangs For Sale (1979-93) Aug 22, 2026
Chrispy62
C
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Resolved 1989 Mustang GT no spark, no trigger pump relay
  • Nine Finger Wrenching
  • Nov 26, 2023
4K
Fox 5.0 Mustang Tech Nov 30, 2023
