Smog and AC delete
  • Thread starter Thread starter wildstang90
  • Start date Start date May 30, 2008
wildstang90
87
Bristol, TN
May 30, 2008
  • May 30, 2008
I am looking to remove my somg pump and the AC unit. I have looked for a thread about this but failed in finding one. Any way if there is a write up some one please point me that way if not is there anyhting I need to know about removing this stuff befor I start. I have seen a few pics that dont have the pump or the AC unit and it looks like they just used a shorter belt. I this the case or do I need to move stuff around with relocating brackets.
Thanks for the help
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
May 30, 2008
  • May 30, 2008
You'll need the Ford Racing A/C delete kit. About $40.
For the smog pump, just delete it and change the routing of the belt.
Belt size will need to be determined later with a peice of string to measure
smokem331
phoenix, az
May 30, 2008
  • May 30, 2008
I have removed both with out useing the ac delete kit from ford. i ended up going to the junkyard and taking the brakets from a 85-91 ford crown or merc 5.0.
Then it was to autozone to figure out the belt size. I looked but i got rid of my reciepts from there for the belt size, but figuring out the size is easy useing a string.
wildstang90
87
Bristol, TN
May 30, 2008
  • May 30, 2008
Thanks for the info. I started pulling stuff out today. Looks alot diff in there with no AC unit I cant wait till all the hoses and the smog crap is out too.
skunk21
1,203
Taxachusetts
May 31, 2008
  • May 31, 2008
do you still have cats on your exhaust? most will tell you that they clog up w/o air being pumped into them when you delete the smog pump. I didn't delete for this reason, we still smog test in my area so an off road pipe was out.
wildstang90
87
Bristol, TN
May 31, 2008
  • May 31, 2008
I am putting on new headers and an off road X pipe in next week so thats not a problem. car has 170K on it and as of right now the cats are stock so there not doing much anyway.
M
mustang911
  • Mar 1, 2009
92 mustang lx convertible 5.0
I've looked on here for info on belt size for a A/C delete and a smog pump delete kit. And which the A/C delete kit (M-8511-A50) works great. But the real problem was finding the right belt size ( pain in the ass). If you are using factory pulleys the belt you need is a 71.5. From what I notice some people are throwing belt sizes out and not telling if there use aftermarket pulleys or factory. You can find out alot here
Mustang5L5
Mod Dude
Feb 18, 2001
43,333
18,059
224
Massachusetts
Mar 1, 2009
  • Mar 1, 2009
There are way too many variables.
WHat i tell people to do is wrap some string around the pulleys and measure. Then go to a parts store and find a 6-rib belt that lenght and get a size above and below it.
BTW, belt part numbers usually indicate their size. So ABCD600715 would be a 71.5" belt by the last numbers of the P/N.
Cobra_Dusten
246
Marysville, Wa
Mar 1, 2009
  • Mar 1, 2009
WRONG!
this is correct. I ended up with a 72" belt and i have march under drives on my car with the ford racing AC delete.
parrish5o
Dirty South
Mar 1, 2009
#10
  • Mar 1, 2009
  • #10
I removed both from my car without using the delete kit for either. I had to remove my underdrive pulleys and put the stock ones back on to keep the belt from rubbing itlelf on top of the fan pulley.
ID89GT
1,659
18
49
Spokane Valley, WA
Mar 2, 2009
#11
  • Mar 2, 2009
  • #11
Whats the routing you would use if you got stock pulleys and the ford ac delete kit, and removed the smog pump.. I can't seem to find one, and it looks as if the belt would rub right there at the tensioner?
1991notchbackLX
1,483
47
48
New York
Mar 2, 2009
#12
  • Mar 2, 2009
  • #12
disclaimer: i haven't tested the accuracy of this diagram first hand
Cobra_Dusten
246
Marysville, Wa
Mar 2, 2009
#13
  • Mar 2, 2009
  • #13
that short belt is 2" to short for my car
superspec
78
#14
  • Dec 26, 2009
  • #14
does naybody have a part # for the smog delete belt "aka 84.5" belt?"
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
