Smog pump...Pros and Cons
  • Thread starter Thread starter Sevan
  • Start date Start date Mar 23, 2004
Sevan
558
IL
Mar 23, 2004
  • Mar 23, 2004
Hey guys,
I want to eliminate the A/C and the smog pump. With the smog pump not in use will I damage my cats or anything else? All sugestions welcome.
Thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 23, 2004
  • Mar 23, 2004
Running a cats without a smog pump is not a good plan. The cats use the excess air to oxidize the remaining hydrocarbons. Depending on how much oil the engine burns, it may cause them them to carbon up and clog over time.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Mar 23, 2004
  • Mar 23, 2004
You just need to plug the vacuum lines going to the air valves on the pump tubing, plug the pipe that goes into your cats, and plug the pipe that goes into the back of the heads. Do you have to pass emissions because you might not pass the visual with no visible pump in the engine bay. It depends how strict your state's laws are.
Sevan
558
IL
Mar 23, 2004
  • Mar 23, 2004
unfortunately I do have to pass emissions
95GTeee
181
Western CT
Mar 23, 2004
  • Mar 23, 2004
I heard the same thing that jrichker said. I also understand that by sending the air to the cats to help them do their job, it also keeps them from burning themselves up by cooling them slightly - but if that were the case, wouldn't there be air pump lines in front of EACH cat - instead of just on the right side??
larrendeuce
649
Southern NJ
Mar 23, 2004
  • Mar 23, 2004
There are cats that don't use air lines and there are ones that do. The ones that do are better at cleaning up the exhaust. Some cars don't have air lines going to the stock cats at all.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 23, 2004
  • Mar 23, 2004
I haven't seen a cat'ed H pipe that the air input didn't "Y" off, one leg of the "Y" to each cat converter.
subcreep
30
Jax, FL
Mar 23, 2004
  • Mar 23, 2004
What if you aren't running cats? Is the smog pump really neccessary anymore?
joncash
just high enough to be functional
756
The USA's peen
Mar 23, 2004
  • Mar 23, 2004
If the car no longer has cats the smog pump is only along for the ride.
What I don't get is, if you have to keep cats on your car why do you want to take off the smog pump? It doesn't use hardly any power, and if you have to smog the car wouldn't you want your emissions system to be working?
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
T
Engine Broken Smog pump bolt
  • townethug
  • Jun 14, 2025
Fox 5.0 Mustang Tech Jun 16, 2025
limp
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
