smog pump ?
  • Thread starter Thread starter tkareno
  • Start date Start date Nov 9, 2007
tkareno
67
clinton ct
Nov 9, 2007
  • Nov 9, 2007
ok i got the ac eliminator kit and i want to get the smog pump eliminator but im not sure if i were to pass emissions even if i put my stock hpipe back on and added dry gas or something would i be able to pass with my stock hpipe and no smog pump? and, also i have shorter belt because of the ac eliminator would i be able to bolt in the smog pump eliminator while keeping the same belt or would i have to buy another shorter belt
ShortThrow50
923
Pa
Nov 9, 2007
  • Nov 9, 2007
well, if your car isnt emissions exempt, you might have problems. Most states do a visual of your emissions equipmment too. I had my normal inspection/emmission done and than yanked all that bs off, then you gotta keep the car below 5k miles a year which isnt hard if the car isnt your daily driver. Under 5k a year in my state means emission exempt. As far as the smog eliminator. I dont run that. Use a smaller belt. Route a peice of string around your pulleys and the measure the string lenght. There is a diagram somewhere for the belt sizes with deleted equipment but its not 100 percent accurate from my experience, I had to bring back 2 belts until I got the one that fit just right. Yeah the smog eliminator is a waste of money
F
Fox8950
247
Nov 9, 2007
  • Nov 9, 2007
+1 on that ... most of those eliminator kits are made so cheaply they smoke a bearing w/in the first month of running and then you just have a noisy pain in the ass to deal with. (if your lucky and it doesn't totally lock up that is)
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 9, 2007
  • Nov 9, 2007
There is very little benefit in removing the smog pump and associated equipment. The parasitic drag caused by the smog pump is about 2-4 HP at WOT
Some review of how it works...
The Thermactor air pump (smog pump) supplies air to the heads or catalytic converters. This air helps burn the excess HC (hydrocarbons) and CO (carbon monoxide). The air supplied to the catalytic converters helps create the catalytic reaction that changes the HC & CO into CO2 and water vapor. Catalytic converters on 5.0 Mustangs are designed to use the extra air provided by the smog pump. Without the extra air, the catalytic converters will clog and fail.
The Thermactor air pump (smog pump) puts air into the heads when the engine is cold and then into the catalytic converters when it is warm. The Thermactor control valves serve to direct the flow. The first valve, TAB (Thermactor Air Bypass) or AM1 valve) either dumps air to the atmosphere or passes it on to the second valve. The second valve, TAD (Thermactor Air Diverter valve or AM2 valve) directs it to the heads or the catalytic converters. The air serves to help consume any unburned hydrocarbons by supplying extra oxygen to the catalytic process. The computer tells the Thermactor Air System to open the dump valve at WOT (wide open throttle) minimizing engine drag. The dump valve reduces the parasitic drag caused by the smog pump to about 2-4 HP at WOT.
Computer operation & control for the Thermactor Air System
Automobile computers use current sink technology. They do not source power to any relay, solenoid or actuator like the IAC, fuel pump relay, or fuel injectors. Instead the computer provides a ground path for the positive battery voltage to get back to the battery negative terminal. That flow of power from positive to negative is what provides the energy to make the IAC, fuel pump relay, or fuel injectors work. No ground provided by the computer, then the actuators and relays don't operate.
troubleshooting
One side of the any relay/actuator/solenoid in the engine compartment will be connected to a red wire that has 12-14 volts anytime the ignition switch is in the run position. The other side will have 12-14 volts when the relay/actuator/solenoid isn't turned on. Once the computer turns on the clamp side, the voltage on the computer side of the wire will drop down to 1 volt or less.
In order to test the TAD/TAB solenoids, you need to ground the white/red wire on the TAB solenoid or the light green/black wire on the TAD solenoid.
To test the computer, you can use a test light across the TAB or TAD wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker.
ShortThrow50
923
Pa
Nov 9, 2007
  • Nov 9, 2007
Thats true J. However, in my case, I deleted it to clean up my engine bay of the nasty looking plumbing during my mods install below. I didnt delete mine for power purposes
Flavadave4
1,044
21
49
Utica, NY
Nov 9, 2007
  • Nov 9, 2007
Same here, what a big difference (in the looks dept.) it makes once its gone
tkareno
67
clinton ct
Nov 9, 2007
  • Nov 9, 2007
ok so i might run into a problem with emissions, but by taking out the smog pump could that do any harm to the motor?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 9, 2007
  • Nov 9, 2007
If you have no cat converters, you don't need a smog pump.
If you do have cat converters you need a smog pump. Without it the cats will clog and fail.
tkareno
67
clinton ct
Nov 9, 2007
  • Nov 9, 2007
ok i understand that but i plan on taking my cats off and then removing my smog pump but when emissions comes i have to put my cats back on, and without the smog pump i wont pass?
fastford91
254
Niagara ,Ontario, Canada
Nov 9, 2007
#10
  • Nov 9, 2007
  • #10
we have a winner! no it wont pass without the pump! at least i dont think it will! never tried but commonsense says no!and you cant run the cats without the smog pump you ll wreck em!
G
Glenn
939
Houston
Nov 11, 2007
#11
  • Nov 11, 2007
  • #11
I've had no smog pump (well the pump is there, but it's not connected to the heads anymore) for about 25k miles w/out a problem yet.
How many miles should it take before problems could arise? btw I run rich.
bloopbloob
578
Alberta
Nov 12, 2007
#12
  • Nov 12, 2007
  • #12
you have problems now.
J
Joe95StangGT
27
Durham,CT
Nov 12, 2007
#13
  • Nov 12, 2007
  • #13
I ,love how everyone says it wont pass emissions, yet, YOU ARE NOT EVEN FROM THE SAME STATE AS HIM, THEREFORE DONT KNOW IF IT WILL PASS HIS STATES EMISSIONS. Since I am from his state. I can say this. I took my 95 gt and my 88 gt through emmissions, with stock cats on, and ZERO SMOG Equipment. I pass with flying colors everytime.
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Nov 12, 2007
#14
  • Nov 12, 2007
  • #14
On that same note as Joe, I went to the same station as him with cats on (stock H cut down to fit long tubes), and the smog equipment, and although I passed, I BARELY made it. Every car, every station, every state is different. There is only one way to know if you pass...
Take it to a station and try.
J
jimmynug
#15
  • Nov 12, 2007
  • #15
Absolutely correct. Every state, car is different. Also, depends on whether you are running cats for smog pump cars vs. non smog pump cars as to whether they will clog or not. Shoot it even differs as to what county in some states, and even from inspection station to inspection station.
ShortThrow50
923
Pa
Nov 12, 2007
#16
  • Nov 12, 2007
  • #16
who drives there fox over 5k miles a year anyway. Hell I thoght they were all emissions excempt. You guys should get some daily drivers lol.
Save the foxbody from high mileage
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Nov 12, 2007
#17
  • Nov 12, 2007
  • #17
I drove mine 4000 miles in about 3-4 months, and that was missing about half the cruise season. Why build a car to not drive it??? By the way I daily drive an Audi A4, but I like cruising the Mustang a little better!
J
Joe95StangGT
27
Durham,CT
Nov 12, 2007
#18
  • Nov 12, 2007
  • #18
yea but you only had 2 cats n you were lazy to make a 4 cat pipe, to garuntee passing....bum
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Nov 13, 2007
#19
  • Nov 13, 2007
  • #19
Lazy, hell yeah!
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
