Sn95 5.0 TPS
Jacobn4056.
30
Us
I need help here because I’m having constant TPS issues with throttle adjustment. Where as unhooking the ground isn’t solving it.
I have timing right now
But what is the trick to setting these TPS?
IAC?
Surging idle
Check engine
Rough
Not consistent
There are times where I’ve gotten it running better.
How do I perfect these tps issues and reset?
  • Useful
Reactions: General karthief
There is no setting of the TPS. It's non adjustable the way the ECU takes a baseline reading each time you start the car. If the parameters fall outside the range, you get engine codes. So if you pull codes and there are no TPS related codes, the ECU isn't seeing anything wrong. Most you can is hook up a voltmeter and see if there are dead spots or it does not sweep full range properly.
