SN95 Rear Swap E-brake setup ??
twoloosescrews
29
Bowie, MD
Hey guys, quick question. I recently bought another fox body mustang that already had the 5 lug swap all around. It has the rear out of an SN95 but the E-brake has not been hooked up yet..Can someone tell/show me what I need to finish it up so I can have an e-brake?
Is this what I need? 1 or 2?
1987-92 Mustang Rear Parking Brake Cable for Rear Disc Brakes at LRS - Same Day Shipping!
My Car
Reactions: Shakerhood
I am at the end of doing the cobra brake swap and have gotten to the e-brake cable. I tried to order the parts from Ford racing and was told the rear cables are no longer available.
Called Late Model resto and ordered all 3 cables from them. They still have the front cable from Ford racing but the rear cables are now apparently being made by SSBC. Of course the cost is more but what else are you gonna do??
You can use the cables from the 95GT. You will need the front mounting bracket (that attaches in the tunnel) to mount the front end of the cables. I would use the e-brake handle as well from the 95. You may need to rework the rear mounting tab though.
I did this same set up on my 90GT. I used a e-brake handle from a 2001 V6. I had to cut the rear tab off and reweld it on about an inch forward. The nice part of doing this is the spring on the handle is already correct - no further mods needed. You could use your foxbody handle as reference for the exact measurement.
Handle with rear tab relocated.
Front cable mount, not the holder with the center rivet.
