SN95 TB VS Fox TB dyno comparo.
  • Thread starter Thread starter Venom351R
  • Start date Start date Apr 26, 2010
  • 3
  • 4
First Prev 3 of 4 Next Last
ProKiller
3,064
15
78
PA
Apr 27, 2010
#41
  • Apr 27, 2010
  • #41
GTA_V6_Mustang said:
and there you go prokiller just check what nmcgrawj poster for a good example.
Thats a good start but hardly an answer. I'm really amazed at the flow rate differences that Accufab has. Are we to assume that they are 5.0 throttle bodies or they could even be 4.6 TBs. We don't know if the way the Idle openings effect the flow or not for example. I wouldn't think it would matter much but its another unknown variable.
I got flow numbers from Edelbrock:
70mm fox #3825 - 625 CFM
70mm sn #3845 - 625 CFM
75mm fox #3826 - 700 CFM
75mm sn #3846 - 700 CFM
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 27, 2010
#42
  • Apr 27, 2010
  • #42
Since when is everyone's flow numbers created equal? Edelbrocks has some serious slack to pick up. I would hate to see Pro Products numbers.
Venom351R
4,548
41
98
MAINE
Apr 27, 2010
#43
  • Apr 27, 2010
  • #43
Accufab TB's are the MM size as stated all the way down to the throttle blade. IIRC other TB's are the MM size as stated by the opening and then taper down. I'm not sure if thats the exact explanation but I know it was something like that that made the Accufab TB's different then others.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 27, 2010
#44
  • Apr 27, 2010
  • #44
Cool.
But even edlebrock vs. holley is laughable.
Im glad i got an accufab years ago
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 27, 2010
#45
  • Apr 27, 2010
  • #45
I totally agree with what nmcgrawj is saying. If you're looking to pick up serious power, don't waste your money on all kinds of throttle bodies. I run an old 70mm BBK Edelbrock throttle body I got at a car show, and a 73mm MAF. The manifold pressure still drops to zero at full throttle. A basic throttle body is going to outflow any one of our engine combos anyway. That's why I didn't see merit in this whole debate about switching to a Fox setup. The fox setup is an older design that is known for jamming, especially with aftermarket throttle bodies. One of the marked improvements with the SN was the improved quality of the throttle body. I don't see the point in messing with it.
Kurt
Venom351R
4,548
41
98
MAINE
Apr 27, 2010
#46
  • Apr 27, 2010
  • #46
Kurt
Like I said the throttle response and better idle makes it well worth it. Ive never had as good of an idle as I do now off any other SN95 TB set up tuned or un tuned.
Last5.0
404
Apr 27, 2010
#47
  • Apr 27, 2010
  • #47
The only reason the throttle response feels better on a fox is because of the angle/shape of the cam that the cable connects to on the TB. I've owned both Fox and SN95 cars for many years and I personally dont like the "super touchy" feeling gas pedal the Foxs have.
And if you can't get a good idle with a SN95 setup then either something mechanically is not working correctly or you need a new/better tuner
GTA_V6_Mustang
1,326
Miami, FL
Apr 27, 2010
#48
  • Apr 27, 2010
  • #48
All I have left to say on this is 351 your car is awesome Definately want to see some new times for the beast.
Venom351R
4,548
41
98
MAINE
Apr 28, 2010
#49
  • Apr 28, 2010
  • #49
Ive been using the same tuner for years he does great work knows mustangs very well. All the components on the 94/95 set up had been tested and working properly, TPS..exc exc... All I know is my car idles sooooo much better then it ever has before and the only major change is to the fox set up. Plus I love the snappy throttle response, its sweet
Venom351R
4,548
41
98
MAINE
Apr 28, 2010
#50
  • Apr 28, 2010
  • #50
few more weeks hopefully
Last5.0
404
Apr 28, 2010
#51
  • Apr 28, 2010
  • #51
It's only snappy when you barely press the accelerator like slowly driving through a parking lot. It doesn't matter when going WOT at the track...lol
Besides, with having ~500rwhp and a Stage 3 clutch which is like an on/off switch anyway, I need as much un-snappy-ness as I can get off idle
Black95GTS
1,644
Marlborough, MA
Apr 28, 2010
#52
  • Apr 28, 2010
  • #52
It's too bad people don't race flow benches.
Adam
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 28, 2010
#53
  • Apr 28, 2010
  • #53
Upgrade to a 3+ or 4+, it's not snappy at all.
Kurt
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 28, 2010
#54
  • Apr 28, 2010
  • #54
Yeah, I don't see how having a fox throttle body makes it idle better or gives it better throttle response. My 347 idles great at 900 rpms.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 28, 2010
#55
  • Apr 28, 2010
  • #55
Kurt
He's at a stage 3 already
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 28, 2010
#56
  • Apr 28, 2010
  • #56
Yeah, the "+" models are totally different though. They handle 800 ft.lbs of torque over the 680 ft.lb. the standard 3 or 4 handles. The "+" models are full faced, which gives them much smoother engagement.
Kurt
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Apr 28, 2010
#57
  • Apr 28, 2010
  • #57
Kurt
Didnt realize there were the "+" models. Thanks for the lesson!
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 28, 2010
#58
  • Apr 28, 2010
  • #58
The only difference between a 3 and a 4, is that the 3 has a sprung hub, and the 4 has a solid hub. I took a chance, and went with a 4+ solid hub model. I'm very pleased with it. It engages very smoothly.
Kurt
Last5.0
404
Apr 28, 2010
#59
  • Apr 28, 2010
  • #59
My Stage 3 is a Hybrid model. That's what they called it when I got it years ago and they said it was something they were just starting to come out with. It has the grip of a stage 3 but the pedal feel of a stage 2. Don't know if it's the same as what they now call 3+ or not. I bought it from SPEC at the 2nd to last World Ford Challenge that was here in St. Louis, so about 5 years ago?? It is a full surface design and not the 4 puck design
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 28, 2010
#60
  • Apr 28, 2010
  • #60
I've had two SPEC 3s and the 4+. They do a lot of experimentation though. I had the original SPEC 3, which was very grabby. The new one I have is great.
Kurt
  • 3
  • 4
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
H
Hello all from my shop, Tod/ Tods Hot Rods, located in Moorpark CA 93021. Longtime 25 Yr Restoration/Performance Shop and Custom Builder Owner. Tod
  • Hot Rod Tod
  • May 28, 2024
  • The Welcome Wagon
The Welcome Wagon May 28, 2024
LILCBRA
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Y
Dyno Comparison for TFS 44cc Ported Heads vs PI Ported Heads with same VT Stage 2 Cams
  • Yel2002GTAuto
  • Oct 13, 2022
  • SN95 4.6L Mustang Tech
10K
SN95 4.6L Mustang Tech Jan 29, 2023
Yel2002GTAuto
Y
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
