So after 160k miles... something let go **PICS**
  • Thread starter Thread starter BigHairyMonkey
  • Start date Start date Sep 6, 2007
  • 3
First Prev 3 of 3
BigHairyMonkey
411
Houston (Bellaire) TX
Sep 22, 2007
#41
  • Sep 22, 2007
  • #41
ok got a vacuum gauge and at idle with the car pretty warmed (700-750 rpm idle) i am seeing 15 in HG. Is that where i should be at? If i let it idle at 800-900 it reads 17 HG and at 1100 its a steady 20 HG so i dont think its a sticking valve or anything. Still problems still persist. Hesitation at part throttle at random occurences, lack of power at WOT (always), and a really lopey idle. It seems like the car runs a bit better when its colder outside ???? sooo.. the things that have been done/checked...
-checked the vacuum
-checked the timing (14 adv spout out)
-new plugs (gapped at .054)
-new wires (FRPP)
-checked fuel pressure (37psi vac off)
-set the the tps (.99)
-ECT & ACT sensors where changed w/ new FORD units less than a month ago
-The MAF is clean & functioning properly (75mm PRO-M calibrated to 19lbers).. clocking it does nothing.
It seems wierd to me that the car runs better at some times than others. 1 thing that never changes is that it really slow WOT. It revs smooth but doesnt pull at all.I am open to suggestions. again.
BigHairyMonkey
411
Sep 22, 2007
#42
  • Sep 22, 2007
  • #42
Also i checked to make sure the CAI is on properely and went and bought new clamps for it to make sure im not getting in any air past the MAF.
PUNISHER RACING
1,124
FORD CITY, PA.
Sep 23, 2007
#43
  • Sep 23, 2007
  • #43
Have you pulled all your plugs and checked them yet, it sounds like your trying to burn water? Alot of times when a car is overheated the heads or even the block distorts causing the problem to never really be fixed if it wasn't properly checked first. I would start by getting the engine up to temp, pull all your plugs and check them, run a compression check on all your cylinders and record them. Start there. Once you realize the motor is worth working with then you should bring your motor to top dead center (comp. stroke) and check all wiring and timing marks. Remember to check for vacuum leaks also everywhere(use wd40)
BigHairyMonkey
411
Sep 23, 2007
#44
  • Sep 23, 2007
  • #44
ill try that. thanks
BigHairyMonkey
411
Sep 23, 2007
#45
  • Sep 23, 2007
  • #45
also... the car has never 'overheated' while i have owned it. I've had it up there prob 2-3 lines away from the top on the stock gauge, and that was when i had e-fan problems. Ive never had it actually peg the stock gauge or anything so i dont think (well i HOPE TO GOD) that the heads/block/intake surfaces didnt get warped so they are not seating right..
  • 3
First Prev 3 of 3
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
