the following is all copied/pasted from a gaming website so the description is larger and somewhat indepth since many of them only go by looks.
this is an '88 LX Hatch. it has 5.0 badging for some odd reason but it has a 2.3 with the a4ld(overdrive transmission). it has an 8.8" rear end with 3.73 gears and the 4-way shocks to eliminate wheel hop. i have a 2.3 turbo motor out of a TurboCoupe Thunderbird that i plan on swapping in along with the wiring harness, a 255 lph Warlboro(sp?), larger injectors(undecided) and when i get more $$, get a recalibration. my goal is to have it running a good 23-25 psi. i have a volvo intercooler for it and plan on methanol injection. the tires that are currently on this are weather-checked so i plan on leaving the a4ld transmission in and burning off the tires along with the clutches and then put in a c4 once i get one. this car has no cancer, or at least i havent found any as of yet. it needs vacuumed because it has mouse turds all over from sitting for 3 years, a new gas tank will probably be needed, too. i would appreciate comments, suggestions and/or questins.
I have the fender and it's in perfect shape along with the side molding...
Believe me its a brand new car afterword.
