  • 1994 - 1995 Specific Tech
So I talked to my engine guy today....
  • Thread starter Thread starter parchisi
  • Start date Start date Feb 28, 2007
parchisi
519
New Mexico
Feb 28, 2007
  • Feb 28, 2007
...and found out that my compression ratio is 10:1. A little high for a supercharger, but doable. So with this little nugget of information, I go back to the question I asked a while ago. How much boost can I safely run on my combo? Thanks guys.
Y
YELLOW 94
428
Rio Rancho NM
Feb 28, 2007
  • Feb 28, 2007
I'd say 6-8 pounds. That compression is kind of high to run more than that. Thats just what I think.
later
Orlie
reddy351
560
12
38
Columbus, Ohio
Feb 28, 2007
  • Feb 28, 2007
I agree with 6-8 psi. The good news is that you won't have to mess around with plumbing a pesky intercooler. If intercooling IS desired, you should be able to get what you need from meth injection or even a little (50hp or less) hit of nitrous.
parchisi
519
New Mexico
Feb 28, 2007
  • Feb 28, 2007
well I was planning on going with a Procharger intercooled anyways. Would having an intercooler affect how much boost I can handle? Or should I just go 6-8 without the intercooler? And what about mixing in some racing fuel?
reddy351
560
12
38
Columbus, Ohio
Mar 1, 2007
  • Mar 1, 2007
You need either cooler air or octane. Race gas is usually higher octane. As is alcohol. (Either in the fuel or injected into the intake.) You can even use just water injected into the intake. Nitrous will also "intercool" the intake charge that way. Of course an intercooler can only do so much. I personally think that it would be a waste of time and money to intercool a low boost application, like yours. The intercooler is used to offset the rise in intake charge temps due to high boost. Most cent SC's are designed for much higher psi than you'll be running. It will be even more efficient there. You will not be compressing the intake charge by a huge amount because of your higher cylinder compression.
That said, it really isn't THAT difficult to add the intercooler to the installation.
parchisi
519
New Mexico
Mar 1, 2007
  • Mar 1, 2007
Thanks a lot for the info reddy. I e-mailed procharger, and they said no more than 10 PSI, so I guess I'll split the differene and go 9 psi. Following what you said, I guess I won't go intercooled but I may add one down the line or go with meth injection so I can bump up the timing a bit. Thanks for the help.
D
Progress Thread Today in the shed........
  • Don7Up
  • May 5, 2026
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
DadLife0724
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
