Some advice needed
  • Thread starter Thread starter townethug
  • Start date Start date Nov 10, 2005
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 10, 2005
  • Nov 10, 2005
Ok, so here is the deal. This summer I would like to do a h/c/i combo. My current mods are in the sig below. Long run I want to get a sc making about 450 horses. I was planning on getting trick flow street heat intake, afr 165 heads and a e303 cam. Will these parts support the flow I am going to need with a supercharger making 450hp later down the road? Also I should see a noticable difference now, right? If not I am open to suggestions. Also, are there any other things that I am going to need or should upgrade while I am doing this. I am trying to figure out if I will have the extra cash to do all of it this summer. Thanks in advance.
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 10, 2005
  • Nov 10, 2005
Also i forgot to add, i have seen some posts saying that the trick flow heads are actually a better head then the afr. If this is the case then how would the cam in the trick flow street heat combo hold up with a supercharger. anyone running this combo? I thought i remember reading that some people have had trouble with the fit of the trick flow heads? Is this true as well.
Thanks
I
IntenseBlue
946
  • Nov 10, 2005
If it were me, I'd get the 165s, Street Heat, and send Comp Cams an email to see which cam they'd reccomend.
I
IntenseBlue
946
  • Nov 10, 2005
284hr.
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 11, 2005
  • Nov 11, 2005
So you think that the heads and intake will support 450 hp but would recommend getting a comp cam? Is it possible to get a cam that will yeild a good improvment in power na but still work well with a supercharger?
I
IntenseBlue
946
  • Nov 11, 2005
With a blower that horsepower is reachable. Comp Cams are THE leaders in cams. That cam will probably be fine N/A.
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 14, 2005
  • Nov 14, 2005
I still need some advice as to what else I should upgrade. Should i go with new rockers, should they be roller rockers, 1.6 or 1.7? I guess i will need some new fuel injectors, anything else?
gcwh02
515
pottstown, PA
Nov 14, 2005
  • Nov 14, 2005
if your going all out, maybe consider buying the TF track heat manifold with some TW heads and a comp cam to match up your combo, AFR's would work too
gcwh02
515
pottstown, PA
Nov 14, 2005
  • Nov 14, 2005
bigger injectors, pump, TB, MAF, probally a good idea to get a ignition setup when you supercharge it too
T
townethug
20+ Year Stangneter
May 17, 2004
124
Nov 14, 2005
#10
  • Nov 14, 2005
  • #10
I have had some consern about the fit of trick flow wedge heads. Anyone have any problems? I would not mind getting them, they seem like nice heads, i just dont want to run into any problems if i am doing this for the first time.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
