Some questions about automatics...
  • Thread starter Thread starter CManT1914
  • Start date Start date Oct 19, 2004
CManT1914
3,172
Killeen, Texas
Oct 19, 2004
  • Oct 19, 2004
Okay, I have never owned an automatic in my life, so I don't know a lot about them. Somebody tell me what the difference is (if any) in a torque converter, a stall converter and a shift kit. Are they the same things, only called different names? Also, can somebody tell me where I can find the gear ratios in Mustang automatics? Thanks
ninety15.0
1,336
  • Oct 19, 2004
Well im not a pro on automatics either but this is what i have learned. A torque converter and a stall converter are the same thing. I think most people just refer to stall converters as aftermarket toque converted with a higher stall speed. The higher the stall speed the more engine rpm you can build before the car moves...which translates into quicker holeshots. A shift kit simply firms up your shifts...it will raise your stock shift points a little and make the tranny slam into gear more quickly again for quicker et's. The stock rear end gear ratio for an auto is probably 2.73. most people who upgrade their rear end go with either 3.90's or 4.10's for automatics. hope this helps.
CManT1914
3,172
Killeen, Texas
Oct 19, 2004
  • Oct 19, 2004
Thanks for the info. Although I know about rear-end gears, I'm talking about the gearing in the actual tranny. Does anybody know the gearing in the tranny itself? I know my T5 but not the autos.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
p0740
  • Roont
  • Oct 19, 2025
2005 - 2014 S-197 Mustang -General/Talk- Oct 19, 2025
horse sence
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
