87Mustang351 said:
thanks alot man i will deffianly take a looka t the staging a guy i know screwed that up and got a good picking on about it lol, but with my lake woods my car hooks up reallllly well, i only chirp 3rd gear, i have been praticing a good bit and i can take off and not squeal first but im launching from idlewhich is no good, so ill try revving it at 1500 RPM or so
but i get a little sideways in 2nd
anyways like i said hopefully i can have the slicks.
another question is when im at the line i only got 2 feet how will i be able to stop the car from rolling when im trying to idle it at 1500 and hold the clutch in? i was thinkin pull up a touch on the e break and soon as i hit it pull it down n shift second? good or bad idea?
Ok there's a couple things here. Most guys rely on roll control or a linelock, but i don't see them as necessary. Most tracks are actually flat enough that you won't roll unless your tires are ROCK HARD, which the backs shouldn't be (you can actually inflate the fronts a bit hard and reduce rolling resistance). If you find that your car does want to roll, then you've gotta heal-toe it. This means your left foot is all clutch, and your right foot is half on the brake and just enough on the gas to keep it where you want to launch, and then when you launch you let off the brake and roll your foot over to the gas and go from there.
Also, practicing on the street is a good start, but the track is a whole different animal. The surface is usually very smooth so that slicks will hook well, and because of that your street tires will usually hook even less at the drag strip than they do on the street.
You also need to do a decent burnout. You don't need to destroy your tires...that only makes your tires gooey and it's a waste. You want to do a 2nd gear burnout because it's easier on the car and you'll spin the wheels faster with less RPM. Burn out long enough to get a good amount of smoke, but you don't need to kill all the wildlife in the surrounding mile LOL.
Personally, i drive around the water box. I do because you only drag water up to the staging line with you, which you in turn drive through on your way out and lose traction. Also, if you burnout in the water box, you sling water up into the fenders which then drips down on the tires while you're staged and that defeats the purpose.
So...drive around the box, and then try to pick a spot in the box that's "between grooves" or so that your tires are on a good flat surface. Some burnout boxes are trashed and look like ruts in the ground. Once you do your burnout, don't head straight to the line...stop, and then drop the clutch a little bit from 1st gear and see how the tires bite. You want to hear some squeel from the tires...this lets you know they're nice and warmed up. You'll feel it when you pop 1st if your tires are warm enough because they'll bite pretty good in the roughs spots in the box.
Getting out of 1st gear without blowing your traction is key. If you can't land a good 60 foot, you'll never see what your car is really worth.
